seperating engine from tranny, general swap issues
Old Apr 17, 2008 | 01:57 PM
4x4Max's Avatar
..i did pull the pass. side axle. What am i missing here? Do i HAVE TO drop the tranny
Old Apr 17, 2008 | 02:21 PM
eng92's Avatar
You have to separate them enough so that the input shaft splines are clear of the clutch disc.
Old Apr 17, 2008 | 02:22 PM
4x4Max's Avatar
about how much is that? I have it seperated about an inch right now.
Old Apr 17, 2008 | 05:14 PM
njmaxseltd's Avatar
Something tells me you bit off more then you can chew.
Obviously you need to pull the tranny further then 1" so the input shaft clears.
Old Apr 17, 2008 | 05:24 PM
4x4Max's Avatar
You are correct, this is much more then i have ever done before, but paying somebody to do it isn't an option right now, so i have to learn as i go! Kinda sucks to have to do this since i was planning to sell the car within the next 2 months...
I'll drop the tranny then. Any hints on getting it bolted back up to the new motor? Like, lifting it back up and alligning it?
Old Apr 17, 2008 | 05:53 PM
Jime's Avatar
Remove them together and then separate them. Drop them both onto the ground and pick the car up, slide engine and trans out, much much easier.
Old Apr 17, 2008 | 07:00 PM
Snypa's Avatar
never done this, but sounds kinda easy...shud i say easier.
Old Apr 17, 2008 | 10:23 PM
QNO_A32's Avatar
since you already have it unbolted and a 1 inch gap,just pull it out more and put it on the ground, than pull the engine. when you put it back together do what Jime said. connect the engine and tranny together than drop them in.
Old Apr 17, 2008 | 10:26 PM
black_maxed95's Avatar
since you already have it half separated, you should remove the driver side axle, and completely drop the tranny from the engine. Other wise bolt it back on to the engine and remove them together as Jime suggested.
Old Apr 18, 2008 | 04:51 AM
SNOMAX's Avatar
PM me for LCA's!
Even though you have a 1" gap, you still have the pressure plate (for manual) and torque converter (auto) to clear, which stick out a good distance inside the bell housing. If it's a manual you can try depressing the clutch, unless all you lines are disconnected, then manually move the fork.
Otherwise, drop the crossmember if you havent already, remove the passenger side engine mount and slide the engine further away from the trans. If that is MORE work than dropping the trans, just drop it and call it a day. Or throw a couple bolts back in the bell housing and remove engine and trans together as Jime suggested.
Old Apr 18, 2008 | 05:18 AM
4x4Max's Avatar
Great suggestions. I'm going to take the other axle and tranny mount off, then drop the tranny. Since the engine is basically already laying on top of the engine mounts, i think at this point it would be easier to get it from the top, but i'll definitely use the bottom when i mount everything back up. Keep the suggestions coming. Right now i'm mostly concerned about putting everything back together and having everything actually allign.
Old Apr 18, 2008 | 11:13 AM
4x4Max's Avatar
I can't drop the tranny, it's getting stuck; any hints? i can't get the input shaft out, so they're still moving as one piece in the middle...
Old Apr 18, 2008 | 01:07 PM
4x4Max's Avatar
Ok i got everything out, now it's just a game of getting the new engine bought and put it...
Old Apr 18, 2008 | 03:17 PM
ajcool2's Avatar
Is this a DEK or 3.5 swap?
Old Apr 19, 2008 | 08:57 AM
4x4Max's Avatar
It's a DE swap.
Old Apr 19, 2008 | 09:42 AM
ShinseiRyu's Avatar
I'm also doing a swap to a another DE since my old engine blew a headgasket. Is there an easy way to drop the transmission without a transmission jack? Would a floor jack and 2x4 work? I also need to get an engine hoist to pull the engine out.
Old Apr 19, 2008 | 10:20 AM
pmohr's Avatar
No more Maximas...
Yes, that'll work. Alternatively, just drop it down onto your chest, then onto the ground. No need for a jack at all.
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Supragte
Aug 12, 2015 10:00 PM
