What DO YOu do ABOUT RATTLE in the TRUNK!!!?!!?
Old Apr 18, 2008 | 01:19 AM
The Russian's Avatar
i have one 12 inch sub in the trunk, everything sounds great inside, but outside sounds like ive locked a midget in the trunk and he's kicking trying to get out. Does anyone use dynamat? or can give me any advice on what my options are in stopping the rattle?
Old Apr 18, 2008 | 01:30 AM
riceyasian86's Avatar
Super glue!
I kid. I have 12 inch subs but I don't get any rattling. Is something loose? Check under the rear speakers in the trunk and see if there's anything that needs to be tightened or needs tightening.
Old Apr 18, 2008 | 01:31 AM
Thakidmeen's Avatar
Yea mayne, I also have 2 12's in the trunk and u would def need to Dynamat it. I have a Dynamat trunk Kit in mine, and it def reduces the rattling, it still rattles but not like it does without Dynamat, now it doesn't sound like a bunch of tools rattling in the trunk. Make sure you have someone who can install it really good or you could do it yourself.. It's also like a wall of it in the back of my trunk to, so when someone sits in the back seat the base is not hitting them in the back. You can also put it on, and behind your license plate so that doesn't rattle all over the place too. Hope this helps homes
Old Apr 18, 2008 | 01:33 AM
also try posting here
http://forums.maxima.org/forumdisplay.php?f=21
it's the audio subforum
Old Apr 18, 2008 | 01:35 AM
And if you do get dynamat here:
http://youtube.com/watch?v=-FoxVAb1nks
Old Apr 18, 2008 | 05:50 AM
coachholland's Avatar
I used Dynamat Xtreme on my Durango and not only did it stop rattling, but *greatly* improved the quietness of the interior. Next to tires and suspension, I think it's the single best thing you can do to improve ride quality simply for the sound deadening effect.
Old Apr 18, 2008 | 06:50 AM
Coolsaber57's Avatar
I turn the music up louder.
Old Apr 18, 2008 | 02:05 PM
MAXIMAK99's Avatar
Dyanmat, It will stop the rattle and inside the bass will sound richer.
Old Apr 18, 2008 | 04:32 PM
travmaximas1998's Avatar
i used raam mat
u can find it here
www.raamaudio.com
u can see the product in use in my build log
http://forums.maxima.org/showthread.php?t=552438
Old Apr 18, 2008 | 09:44 PM
SmileyFace's Avatar
hahahaha nice
the cheap way and this greatly works. go to home depot or something, buy wall insulation and all those holes you see on the trunk, stuff them in all the way, be careful not to stuff to much were you unlock the trunk cuz will stiffen. reduced my rattle to nothing, no lie and very light weight FTW
if you have a spare tire, the ring that holds it rattles too.
add dynamate if you want and will only improve the sound quality and noise.
Old Apr 20, 2008 | 12:34 PM
vilmaxima's Avatar
Most likely its your license plate, do that first(Dynamat license plate kits) then go from there, I was gonna do my whole trunk but its fine with it just behind the license plate, I also got two 12"s.
Old Apr 20, 2008 | 07:23 PM
phatty99's Avatar
dynomat,greatstuff
Old Apr 20, 2008 | 07:32 PM
Jess's Avatar
SHIFT_In2D
Slightly cheaper alternative to dynomat is the stuff from Second Skin Audio.
I deadened my doors, rear deck, behind the rear seats, and the whole trunk including the lid. And the 5.5 known to rattle already with the stock bose sub lol.
No rattle inside or out. Can't tell I have audio when I'm next to you unless I open the window. If it seems like its coming from the license plate add a piece of sound deadening material and secure it tightly.
Old Apr 21, 2008 | 01:43 PM
DBear's Avatar
Make sure your jack is tightly in place.
Old Apr 21, 2008 | 01:58 PM
mooseq30's Avatar
dynamat the license plate, behind it and around the bolts, dynamt the sunglass holder under the bolts, and put some wall insulation in the panels in the trunk and around the spare, should work really well! if you wont you spend lots on the dynomat trunk kit and use that, but its heavy? so I would suggest just some light weigh packing of any sort, cotton towel's work too but wall insulation is easier to place!
Old Apr 21, 2008 | 02:49 PM
clint240sx's Avatar
Dynamat for the win!!!
but if you're hearing a rattle, you really shouldnt let that rat run around in your trunk lol im playin.
But i hope you fix your problem
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
