weird suspension squeak
Happens 2 out of 5 times when hitting a bump/pothole with the left side of the car; 2 out of 5 times when doing it with the right side; 4 out of 5 when doing it with both sides of the car at the same time. W-T-F
Im same problem squicking so bad wen hitting the bump i thought it wat my outer tie rod that not tight enough i replace it then my mechanic told me it was my strut. On winter time im not hearing this kind of wierd squicking sounds and if its wet it wont sounds like this.Know its summer time the squicking is so bad.No idea wat it is!
It's hard to say unless you get up under the car and take a look. It is most likely bushings, but which ones they are is nearly impossible to judge unless you take a look. I would put it up on ramps, crawl under it, and have a friend wiggle the car around.
**Be careful not to use too much force when doing this!!!**
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
HerpDerp1919
09-29-2015 02:02 PM
