steering REALLY loose!?!?!
Old Apr 19, 2008 | 07:11 PM
webjohn's Avatar
my steering wheel is super loose. there is alot of play, like when i hit a bump its like im hydroplaning. and the faster i go the looser it gets, on the highway i have to hold it with 2 hands because if i hit a bump it goes out of control?
Old Apr 19, 2008 | 07:35 PM
pmohr's Avatar
No more Maximas...
Was there a question there?
If you're having steering/suspension problems, it seems to me that the first course of action would be to check out the steering and suspension
Old Apr 19, 2008 | 07:42 PM
webjohn's Avatar
what part of the suspension should i check?
could the rack and pinion cause that?
or what else could it be?
enough questions? ha
Old Apr 20, 2008 | 05:39 AM
njmaxseltd's Avatar
All of it
Yes
Tires, the driver perhaps.
Old Apr 20, 2008 | 05:54 AM
dgeesaman's Avatar
Maintenance Monster
Drive it carefully to a tire/alignment shop and have them check it out.
Dave
Old Apr 20, 2008 | 03:27 PM
vqmaxman's Avatar
I think there could be air in the system or the rack and opinion is failing.
Try checking the power steering resovior If it's empty or if it's low and If there's any leaks.
Old Apr 20, 2008 | 03:28 PM
nismology's Avatar
I'd check the rack/LCA bushings/tie rod ends/ball joints.
Old Apr 21, 2008 | 05:51 AM
webjohn's Avatar
there is a leak and the power steering is running low so i would suspect its power steering leak.. but i dont no where its leaking from. where could the power steering fluid leak from.
Old Apr 21, 2008 | 07:17 AM
soccerplr19's Avatar
i had the same problem rack & pinion was bad got it replaced, my steering still feels like driving a cadi, but thats cause my struts are bad as well
Old Apr 21, 2008 | 07:23 AM
maximase86's Avatar
I love lamp.
You might try getting under the car an look at the P/S line connections. Lots of build up around the connections could indicate bad seals or lines. Otherwise it's a good chance the rack itself is not good. It could also be a pad P/S pump too.
S
Old Apr 21, 2008 | 09:31 AM
dgeesaman's Avatar
Maintenance Monster
If the passenger side of your engine and frame isn't covered in PS fluid, then it's probably the rack leaking. The corrugated rubber boots on each end of the rack are supposed to be dry inside, but I'll bet one or both of yours are all oily.
Dave
Old Apr 21, 2008 | 12:57 PM
Iron Scimitar's Avatar
Tha Snatcher
suspension forum.
Old Apr 21, 2008 | 04:12 PM
blumax1023's Avatar
OK...I HAVE HAD THE SAME PROBLEM.....ITS YOUR LOWER CONTROL ARM BUSHINGS.....GO TO A SHOP THAT IS NOT REALLY LIABLE OR HAVE A BUDDY DO IT.....MY DAD WORKED FOR NISSAN FOR 27 YEARS IN PARTS.....USE 1989 MAXIMA BUSHINGS OR ELSE YOU PAY MEGA MEGA BUCKS FOR IT!!!...ITS A LITTLE TRICKED I LEARNED
Old Apr 23, 2008 | 05:03 AM
webjohn's Avatar
Dave
yes the rite side of my engine from top to the bottom of the oil pan is covered in oil
Old Apr 23, 2008 | 05:05 AM
webjohn's Avatar
double post srry
Old Apr 23, 2008 | 05:22 AM
webjohn's Avatar
ok, ill change them, lets see if that fixes the problem
Old Apr 23, 2008 | 07:16 AM
TunerMaxima3000's Avatar
Old Apr 23, 2008 | 08:18 AM
Snypa's Avatar
you prob need alignment and change of springs.have a mechanic feel it out.
Old Apr 24, 2008 | 06:32 AM
dralucard's Avatar
i had the same problem when i bought my car - very loose suspension, especially if i hit some bumps going around a curve on the highway. it was the rear struts. the car had 145k so i changed all of the struts, springs and mounts. totally different car. if your over 100k and you don't know if the struts were changed, have them checked.
Old Apr 24, 2008 | 06:40 AM
Crusher103's Avatar
could u please.......
i think its Ur LCA bushings and also check Ur tie rods aswell
Old Apr 24, 2008 | 08:09 AM
webjohn's Avatar
well if i change all of those things i might as well drop a couple of inches any ways, where can i get the rite pieces to drop the car?
D Mason
Jun 21, 2016 04:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
