car idles then shuts off
Old Apr 24, 2008 | 11:33 PM
anik151's Avatar
so today i was going for a drive, i turned the car on i put it in drive, then when i went to press the gas the car studerd and then it shut off. so i tried it agin and shure enough it did it again. so i poped the hood and tried it again the car turned on then the engine staretd to shake and it shut off. im not sure if this is the spark plugs the coils or what. any thoughts.
Old Apr 25, 2008 | 12:01 AM
KRRZ350's Avatar
Highly doubt it's either of those things.
IACV, maf, and evap valve are some of the many possibilities. Popping the hood didn't help though? Hummm. In that case I'd go ahead and scan the codes.
Old Apr 25, 2008 | 12:14 AM
anik151's Avatar
what part of mass are u from ? im about 30 mins from boston
Old Apr 25, 2008 | 12:18 AM
anik151's Avatar
well popinng the hood didnt make it worse i meant that i noticed that the engine shook a little bit befor it turns off
Old Apr 25, 2008 | 06:16 AM
sicivic89's Avatar
Check engine light on? This will point you in the right direction.
Old Apr 25, 2008 | 06:54 AM
dj6230's Avatar
you considered if it is startblocking or what its called?
Old Apr 25, 2008 | 06:57 AM
dj6230's Avatar
i just read about it in a norwegian maxima forum, some1 said adding resistance on the watertemp sensor would fix such problems...
Old Apr 25, 2008 | 07:43 AM
Snypa's Avatar
Are there any codes.? Im guessing its either the maf or coils. Could be both maybe. But thats what happens when the maf is unplugged or just not working.
Old Apr 25, 2008 | 07:50 AM
maf2003111's Avatar
Im going to guess there no codes bc u didnt mention the CEL on, so im going to guess MAF too. had the same problem, i picked up a used some at a local import junk yard for $60 and hasn't failed yet
Old Apr 25, 2008 | 07:53 AM
dj6230's Avatar
YES there are codes, when you reset it, go to you local nissan dealer and get them to add a new one!
Old Apr 25, 2008 | 10:15 AM
anik151's Avatar
i have 1 code but its for the knock sensor someone also told me that i should try cleaning the IACV does anyone else think this might help ?
Old Apr 25, 2008 | 10:32 AM
hot_wax_tree's Avatar
what the crap are you talking about.......?
I would say go to the yard and get another one, or clean it.
Old Apr 25, 2008 | 10:43 AM
dj6230's Avatar
im talking about the start blocking....im not sure what its called in english, but you know you reset it by enter the key and twist it 2 clicks to start mode and waith 5 secs and twist it back and remove the key, then the car should start, but for saftey you need to get a nissan dealer to enter a new code...
Old Apr 25, 2008 | 01:42 PM
anik151's Avatar
which one is the maf sensor ?? i just recently started fixing my own car with this site so i dont know to much but i can fix it if itry ive done all the work on my car and i gotta say thanx to u guys i feel proud i know that was so of topic but wateva
Old Apr 25, 2008 | 02:03 PM
maf2003111's Avatar
the MAF is the "cylinder" piece after ur air filter box. its like $450 at dealer ship, $200 or so at autozone and if u can pick up a used one the better. you can always buy it at autozone test if its it and if its not just return it
Old Apr 28, 2008 | 03:20 PM
anik151's Avatar
could it be my fuel pump?? a friend of mine told me it might be that. but im not sure if its related to the problem cuse it starts up and 5 to 6 sencods later it jus shuts off when i press the gas it shuts down evean faster.
Old Apr 29, 2008 | 07:04 AM
Kevlo911's Avatar
Kevlo for President
Check or replace the ECTS
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
erniel
Aug 8, 2015 09:32 AM
