Is it AFC vs Fuel Pressure Regulator or both???
Old Nov 1, 2001 | 04:21 PM
gould2000's Avatar
Little confused on this one, even after searching for the past 2 days.
So here's the deal: Gonna eventually run higher than 50 shot of NOS. I know one of the things I will need to change is the stock fuel pump. So, let's say i have upgraded the stock fuel pump, and it usually goes without saying the stock fuel pressure regulator cannot handle it. So i need to upgrade the Fuel Pressure Regulator. If I were to install, for example, an Apexi Super AFC, would I still need a Fuel Pressure Regulator. I think I would, because the AFC would manage the Fuel flow in it's relation to Air flow, but not necessarily the Fuel Pressure, which is managed by the Fuel Pressure Regulator.
So basically, my thinking is, you need at least the upgraded Fuel Pressure Regulator. While the Apexi Super AFC is an advanced way of tuning the A/F ratio, but does not control the fuel pressure. Is this right?
Sorry if this is confusing. Thanks for the help gang:-)
Old Nov 1, 2001 | 04:25 PM
Jeff92se's Avatar
I'm needing a caw
That's about right. Although I think most of the nos guys here don't use the SAFC to control a/f ratios. With the way nos is on/off, I don't think it's really needed.
Old Nov 1, 2001 | 07:55 PM
tifosiv122's Avatar
Re: Is it AFC vs Fuel Pressure Regulator or both???
I am running Nitrous and wanted the Apexi S-AFC to control Fuel flow. I called Apexi and they told me you can use it to tune fuel flow BUT you can not save settings. What I mean by this is you need two fuel settings:
1. Running without nitrous
2. Running with nitrous
You should be able to set up the S-AFC to "save" each of these two settings, but you cannot, as stupid as it sounds. Basically everytime you use the NOS and everytime you stop using it, you need to "tune" your S-AFC. This is the stupidist thing I have ever seen. I am not sitting everytime I want to use NOS and messing with it. They should have allowed you to save 2 or 3 settings, but they didn't. I would stay away from this if I were you.
Erik
Old Nov 1, 2001 | 07:57 PM
gould2000's Avatar
Thanks for the input
Thanks for the different insights. Anyone have any other opinions on the Apexi Super AFC?
Old Nov 1, 2001 | 08:41 PM
BriGuyMax's Avatar
no AFC for NOS..it's just not practical.
Yes you will run rich with just the new fuel pump....an adjustable FPR is a good idea...that's all you should need....you can tune your NOS (ON) mixture with different fuel jets when you bump up the shot.
Old Nov 2, 2001 | 05:48 AM
gould2000's Avatar
Glorified monitor only????
So since you cannot ave settings on the Super AFC, Can it be used just as a glorified monitor without the managing of the air-fuel? Kind of like a management only molde?
Old Nov 2, 2001 | 06:09 AM
tifosiv122's Avatar
Re: Glorified monitor only????
The settings save, but you cannot save multiple settings, ie. On and off the bottle. You should be able to modify settings and choose between preset settings.
Erik
Old Nov 2, 2001 | 08:59 AM
mtrai760's Avatar
'Trynna' is not a word
Not that I have first hand experience, but I heard that the S-AFC is not compatable with the Maxima. It works for about 3 hours, then our ECU resets itself and bye bye fuel map modifications. This is just what I heard. Get a fields fuel controller, it's supposed to work fine. You will also need a regulator whether or not you get some type of air fuel controller, because fuel pressure is not regulated electronically, only the injectors are. Therefore, if you have more fuel pressure, you are going to get more fuel unless you replace the Mechanical fuel pressure regulator.
Old Nov 2, 2001 | 01:45 PM
mtrai760's Avatar
Yes it is enough. The S-AFC is used to fine tune you air/fuel ratio's throughout the fuel map per RPM's...
Originally posted by rOaD bEaSt
Isn't enough to use a fuel regulator alone ?
Old Nov 2, 2001 | 11:59 PM
1MAX2NV's Avatar
You can save up to 3 settings with Field's AFC. You can't with Apexi super AFC.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
