Motor Mounts
Old Apr 28, 2008 | 07:33 AM
ray_289's Avatar
Motor Mounts
My rear motor mount has been bad for sometime now and I am unsure of which ones to replace it with. I know i can go OEM or Polyurethane.
DO i have any other choices besides the 2?
And do the Polyurethane ones make the car shake when its idling?
I do drive the car hard most of the time, and my car is slammed on coilovers.
Which mounts would you guys/girls recommend ? And would I be better off changing all at the same time or just one?
ThankS
Old Apr 28, 2008 | 09:07 AM
mooseq30's Avatar
Poly mounts are awesome, one of the best mods you can do! I suggest to get the mounts, control arms, sway bar, cross member, bushings!!! Call Energy Suspension Performance to get all the Polyurethane bushings, they don't make the car vibrate any more than it already does, they also increase reliability, handling, +whp! They reduce wheel hop and reduce the likelyhood of breaking stuff! the control arm bushings are great they make turning feel amazing and the ride ultra smooth(less bounce)! Its really worth it, you can get the rear ones as well if you want to go all out!
Old Apr 28, 2008 | 10:47 AM
f550maranello2's Avatar
uhhh.. i replaced mine (control arm) busings and felt no difference..... i would get oem... its not like they haven lasted 10 years already.....
Old Apr 28, 2008 | 06:39 PM
QNO_A32's Avatar
the poly mounts, front and rear, will give you more vibration at idle but they perform excellently. i dont mind the idle...makes my car feel alive
Old Apr 28, 2008 | 07:24 PM
JSMax's Avatar
Sold
Be wary of the poly mounts espically for the engine mounts. Yes, they do transfer power RIGHT NOW since there is no (or very little) flexing in them. Yes, no torque is lost due to the engine rotating on the mounts. You probably can corner faster and get on the gas a little sooner in the corner to help get you out of there.
I also have sway bar bushing, and endlink bushing and let me tell you with that combination, those were more noticable than when I installed my FSTB.
What I don't like is pretty simple and I'm sure it's an easy fix, but I'm just too busy right now to try and Mcgyver it.... the hood rattles like a **** at idle. Also, 600rpms the steering wheel shakes/vibrates in my hand. You can see it vibrating if you take your hands off the wheel.
A minor thing, but something that should be noted.
Old Apr 28, 2008 | 09:19 PM
ray_289's Avatar
Thats what i was thinking. I DO NOT want any vibration and from what i read thats what the poly mounts give.
-Are there any other mounts that perform like the poly ones but dont vibrate
the steering wheel and what not?
I would'nt mind the vibration but girls already complain how rough my car rides because of my coilovers i dont want to give them another reason to complain lol
Old Apr 29, 2008 | 12:02 AM
maxilac99's Avatar
search how to make your own poly mounts. there is info in there about the different strenght levels of poly. (ie: you can make your own slightly softer poly mount)
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
