after market steering wheel???
Old Apr 29, 2008 | 07:50 PM
aramax's Avatar
hey guys, i have a 96 model and i really want to put in a 12" aftermarket steering wheel, but as i read it's against the law cause i have to remove the airbag, but i still really want to do this. I'm prety sure some of you guys have done it before and i was wondering if there is any writeups for it, AND WHERE do i get the conversion HUB from? can you guys please help me out?!
Old Apr 29, 2008 | 09:10 PM
Snypa's Avatar
ebay is your friend for everything.as for the write-up it shud be around here somewhere. Going without airbag is pretty much up to you.Didnt even know it wa illegal.
Old Apr 29, 2008 | 11:22 PM
MrDicks95SE's Avatar
Offset Is Everything.
PM AuToMaX_95 for steering wheels and hubs. he can get Momo's and i believe Sparcos too.
Old Apr 30, 2008 | 09:37 AM
Pick up a Haynes at your local Autoparts store, or download the FSM for free and read up. It's a very simple procedure granted you have a T50 tamper proof torx bit. You may need a steering wheel puller, you may not (Some orgers have reported the wheel simply pulls off, where I needed the steering wheel puller). Also, use the free search here, this topic has been covered a handful of times in the last few weeks. This will give you further insight of what needs to be done.
FWIW, I'm using a NRG quick disconnect release with a NRG short hub adapter. The cheaper option would be to just get the standard non-detachable MOMO hub or Sparco hub like Mr. **** suggested. I purchased everything from Crower's Customizing found on ebay.
Old Apr 30, 2008 | 09:39 AM
Also, don't forget to disconnect the battery first and wait a few minutes. Then disconnect the yellow airbag connector under the steering column before proceeding with the actual steering wheel removal. Safety first.
Bonka
Sep 14, 2015 11:18 PM
Maxie40
Sep 14, 2015 11:28 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
