PO440 and PO446 aka 0705 and 0903, help please
Old May 4, 2008 | 07:08 AM
caseymaxima's Avatar
Hey everyone,
I am very confused as to the CEL codes that come up on my 1996(POO440 PO446). I have read the diag sticky, however it does not seem to be much help with either code. Has anyone else run into the codes that I have? I know that they point to the evap canister, but nothing is very specific. Are these two codes hurting the performance of my car? How about the gas milage?
Thanks,
Zack
Old May 4, 2008 | 05:09 PM
Anyone?
Thanks,
Zack
Old May 5, 2008 | 12:03 PM
Bump
Old May 5, 2008 | 03:51 PM
svetlin55's Avatar
Originally Posted by caseymaxima
Bump
take out your vent valve,because its stuck,put some wd40 inside and move it around back and forth with the screwdriver .then, reassemle.
Old May 5, 2008 | 05:39 PM
nexgenmax's Avatar
R34
There's a site with evap inspection on it, hope it'll help.
http://www.lyberty.com/car/Maxima_A3...NTB98-073a.pdf
Old May 6, 2008 | 04:19 AM
Thanks! I wonder when the service camp expired? Or did it?
Zack
Old May 6, 2008 | 04:20 AM
Can you give me some direction on doing this?
Thanks,
Zack
Old May 8, 2008 | 05:36 AM
svetlin55's Avatar
Thanks,
Zack
take off the rear driver side wheel and you will see on right side evep canister box and evap vent valve bolted vith 2 10 mm bolts.take it off and put wd40 ,push the piston inside up and down until it unfreese.clear the hoses and check everything for cracks
97_GXE
20
Sep 17, 2015 08:12 PM
97MaxGurl
Oct 26, 2001 01:05 PM
NYCe MaXiMa
Aug 22, 2001 07:54 PM
supraturbo94
May 31, 2001 11:10 PM
abermike
Jan 10, 2001 06:34 AM
