Couple question on the MEVI install
Old May 6, 2008 | 03:03 PM
Scottyboi's Avatar
This manifold was bought from someone on the forums.. and it comes with a summit racing black box.
Well i was woundering where i get power from when i connect RPM switch.
Where do i connect this? It says, Normally open something something, i have to look at that..
another question, could i just run with the butterflies open?
Old May 6, 2008 | 03:06 PM
kzoosho's Avatar
What are you trying to power? The rpm switch or the solenoid?
Old May 6, 2008 | 03:16 PM
NmexMAX's Avatar
dot dot dot ...
Looks like a Summit Switch to me
If so, search : Summit RPM
Old May 7, 2008 | 08:09 AM
Flava_24/7's Avatar
Boosted Panda
For the Summit RPM switch:
Yellow Wire to VSS switch
White Wire to RPM signal (ECU or TAM screw)
Red is 12 volt PWR
Black is GND
Grey is not used
Old May 7, 2008 | 08:11 AM
Flava_24/7's Avatar
Boosted Panda
You could, but its going to kill you performance below the 5k area.
Old May 7, 2008 | 01:44 PM
Scottyboi's Avatar
Red is 12 volt PWR
Black is GND
Grey is not used
Vss switch i assume is the little blue box?
Sorry it didnt come with instructions
Old May 7, 2008 | 02:20 PM
Flava_24/7's Avatar
Boosted Panda
Blue Box? Not sure what your refering to. Post pics of what all you have.
VSS is the Vaccum Solenoid Switch.
Old May 7, 2008 | 02:34 PM
gtr_rider's Avatar
192.168.1.1
Maybe this will give you some clues to your questions:
http://www.vqpower.com/v2/infusions/...?article_id=50
Old May 7, 2008 | 05:07 PM
Scottyboi's Avatar
ALright well i installed it all, and the red light on the summit black box stays on...any idea?
Old May 7, 2008 | 05:16 PM
The red LED indicates that the unit is on.
The green LED inside the unit turns on when at or above the desired RPM you chose....
Old May 7, 2008 | 05:28 PM
Scottyboi's Avatar
Oh, thank alot! i thought i messed up during the install.
One last question, how do i get it to turn on from 5500 -7400? IS this a rpm setting to turn it on?
Old May 7, 2008 | 05:33 PM
Sounds like you haven't read the instructions. Check them out here. Should answer all your questions.
http://store.summitracing.com/partdetail.asp?part=SUM-830449
Old May 7, 2008 | 05:46 PM
Scottyboi's Avatar
Nah i havent read the instruction, i bought it used so it didnt come with any. Thanks for the link
Old May 8, 2008 | 11:29 AM
Flava_24/7's Avatar
Boosted Panda
Once it activates, it stays on untill you fall below the set RPM mark.
To set the activation point you have to adjust the DIP switches and you can fine tune with the little dial.
Old May 12, 2008 | 03:13 PM
Scottyboi's Avatar
I switched the little ***** upward on 5-000 is that a good?
Is their a way to reset my tps? My rpms sometimes stay at 2k
Old May 12, 2008 | 04:07 PM
Assuming you have a decent multimeter, you can check your TPS.
See link.
http://www.vqpower.com/v2/infusions/articles/readarticle.php?article_id=95
Lakersallday24
Nov 7, 2024 07:31 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
Jan 8, 2016 07:21 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
