96 Maxima Sunroof track messed up (1 side)
Old May 10, 2008 | 01:47 PM
JoshBarber's Avatar
girlfriends 96 Maxima has a sunroof issue. the passenger side seems to be stuck in the rear corner. when you put the sunroof into its DOWN (or closed) position, the passenger rear corner of the glass sits below the flush level with the roof.
When you attempt to open the sunroof, the drivers side lifts as it should, but the passenger side remains in the same position unless you manually slide the mechanism within the track (forward). If you hold the forward pressure on the mechanism and attempt to open the roof, it'll open as it should. It will not however return to closed when you close it.
Did a pin or something that makes this move break?
Is this a common problem? Is there a common fix?
Old May 10, 2008 | 02:16 PM
ShinseiRyu's Avatar
I believe this is a common problem, the sunroof in my mom's Maxima is also broke. Last I read was that you had to take apart like all of your roof to get to it though.
Old May 10, 2008 | 02:41 PM
njmaxseltd's Avatar
You can purchase a repair kit for it at your local Nissan dealer. The job is somewhat involved, but DIY capable. The headliner has to come down, to do that you must remove the sunvisors, side pillars and anything else thats bolted to or through the headliner. All the edges must be free and clear to drop down. It's only held up with clips, so gently pry and pull and it will come down. The sunroof assy is bolted onto the roof frame with a few I think 10mm bolts. Take the glass out first, there are 4 bolts under the plastic trim and it just pops out the roof of the car. Unbolt the frams assy from the roof and take it out of the car. Don't forget the disconnect the 4 drain tubes before you drop the sunroof. Then just replace the broken parts with what you get in the kit and you should be good to go.
Old May 11, 2008 | 08:08 AM
NISSANMAXIMA91's Avatar
Funny, I went to my Nissan dealer here, asked about a sunroof repair kit, guy kinda laughed at me, but looked anyway, and nothing came up. Just the whole assembly for 1100$. Do you happen to have the part number for the rebuild kit, or price, or where did you find yours(assuming you got one)?
Old May 11, 2008 | 08:33 AM
gtr_rider's Avatar
192.168.1.1
Repair Instructions
http://www.vqpower.com/v2/infusions/...?article_id=43
FanaticMadMax
Aug 10, 2015 08:55 PM
altome15
Aug 10, 2015 07:05 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
