DEK swap owners
Old May 17, 2008 | 05:47 PM
93altima's Avatar
Turbo 4th Gen
DEK swap owners
DEK swap owners please help i pulled my vq30de today and i bought a dek when i was looking to put it in i noticed all the damm vacuum lines like wtf is all that supposed to go to and theres a bunch of a plugs that i didnt have on my de what do i do about that??? and i know i have to splice the injectors but what about the evap or whatever else
Old May 17, 2008 | 07:14 PM
Product_Of_Korea's Avatar
well im pretty sure that the vaccum lines off the dek compared to lets say a 00vi swap wouldnt be to much diffrent. so with that said i would be looking into some of the 00vi swap sections and what not. and also have you checked out cesars thread. im sure it covers vaccums somewhere in there. also im pretty sure for the evap that you have to make one of the nipples larger on the right side by the tb cause the one there is too small. and the 5th gen evap wont work with the 4th gen ecu iirc. so im pretty sure you will have to use the 4th gen evap equipment
Old May 17, 2008 | 07:52 PM
matty's Avatar
I took my entire Vaccum Gally off of my 4th gen coolant log and made it work on the 5th gen coolant log. It WONT bolt up to the 5th gen Log as nice as it is on the 4th gen Log, so I drilled a new hole in and mounted it right on the side of the motor, after moving one of the sensors. Its fits great, looks good, and functions better than a bunch of vaccum lines going all over the place.
EVAP needs to stay 4th gen equipment, most of the other sensor are interchangable. MOST being the key word.
-matt
Old May 17, 2008 | 10:25 PM
93altima's Avatar
Turbo 4th Gen
well imma take anothor crack at it tomorrow all the vacuum lines are over whelming me i read almost all of ceasears thread he mentions the vacuums but i couldnt find detailed info on where each 1 goes iam good on the evap now and besides that can i use the rear exhaust manifold on the dek it looks very similar to the de one it should bolt up to my stock y-pipe right? and one more thing cant i use the iacv from the dek just turn it upside down ,beak the little tab, and e-tape it right?
Old May 17, 2008 | 10:33 PM
93altima's Avatar
Turbo 4th Gen
Old May 17, 2008 | 10:34 PM
93altima's Avatar
Turbo 4th Gen
sorry for crappy pics
Old May 18, 2008 | 08:18 AM
cant see pics. but i dont know if yo did a typo or what but you can use the 5th gen iavc and yes you turn it and you have to hack off the plastic and remove the rubber seal inside to make it fit on the 5th gen iavc. and yes your y-pipe should hook up.
are you using a 00 engine or a 01 engine? the reason why i ask is the egr equipment. i imagine you are keeping them so i can see why the vacuums would be overwelming. when i did my swap i said the hell with it and chucked my egr. made life a little easier but i realize you might not have that option.
i might be doing this swap soon seeing that my engine has about 160k on it so........... time to bring out the dek just laying in my polebarn
oh yeah host with photobucket it works great for me
Old May 18, 2008 | 11:14 AM
93altima's Avatar
Turbo 4th Gen
i really want to keep the egr but i really just want to know how all the vacuums hook up i took off the gally or what evr its called i have a pretty good idea but theres a bracket on top of the intake thats confusing me and theres a vacuum on the manifold right behind the tps, and theres a vacuum hose thats sticking up on the timing chain side of the motor down where the knock sensor sits where does that go?
Old May 18, 2008 | 02:20 PM
i belive that would be your brake booster line which would hook up to the far left side where only one nipple is
Old May 19, 2008 | 11:15 AM
93altima's Avatar
Turbo 4th Gen
no you know what imma have to post some pics but ill get back on that 1
Old May 19, 2008 | 11:47 AM
XAugusta MoonX's Avatar
Holy crap. Use the search. And periods. Man, you need to get a Haynes manual and follow their figures. It's really easy, you just need to take your time and think it through. Also- All-Motor- Probably a better idea than in here.
jmlee44
Oct 2, 2022 02:13 PM
Mar 12, 2020 12:06 AM
Forge277
Jun 13, 2016 09:26 PM
JonBlz
Oct 5, 2015 06:02 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
