Absolut Pressure Sensor gone bad - help
My dealer said that I have a problem with the absolute pressure sensor. They want me to leave the car there for repair - I'm guessing it will cost a bundle. Anyone know what it does and if I really need to fix it and how I can do it myself?
I am not sure, however the DTC is 0803. Also, if I leave it then the ECU light will always be on and I will never know if there are any other problems with the engine unless I perform diagnostic checks periodically.
I just check the FSM, it is the 'boost sensor'... check for a loose connection/damage to wiring. If there is no apparent damage to the wiring/harness... you can just buy a new one and replace it yourself. You may even be able to get one from a junkyard.
It is attached to the plastic air intake piece just in front of the engine... should be very simple install... unplug/replace...
Good luck!
Good luck!
I checked the wire harness today and read 12Volts on the red. I could not detect any groung faults or shorts so I am assuming the problem is with the sensor. I was not able to get power to the sensor and read what's coming out of it at the same time.
I removed 4 screws off the side of the air intake and removed the cover. All I saw were 3 copper leads. It didn't really look like a sensor. I hope I was checking the right one.
I replaced the cover but got a little dust inside the intake. Will this damage my engine? Forgive me if that's a stupid question.
It's the small sensor mounted between the front valve cover and the radiator, closer to the battery. It labeled "boost sensor"...
I just realized that. I was actually checking the MAF sensor. I hope I didn't break that sensor, as I had to pull quite hard to pull the off of the side of the sensor only to see 3 copper leads.
I'll check the MAP sensor this time. I am not really a big do-it-yourselfer.
lowpost99
05-16-2021 12:18 PM
