Knock sensor problem ... ebay knock sensor?
Old May 27, 2008 | 03:23 PM
mastercoryd's Avatar
Hey i have a 95 maxima with headers and full exhaust and i currently was running the medium grade octane and now im switching to premium... well anyways my knock sensor code is on and i dont know if that is because my car was knocking and it was warning mee or becuase the sensor is broken, but my car seeemd to be running fine n such and never had any knocking.
So just to be safe im going to upgrade to premium gas (exspecially since im going to safc tune my car) and i wanted to know if this soudns like i should replace the knock sensor. I cant really tell if my cars been sluggish because the codes been on for so long i dont even remember
but if i am going to replace a knock sensor i found some cheap like 44 dollar ebay ones that im going to stay away from but i found some more expensive ones brand new from ebay stores that seemed like a legit deal that go for like 70 bucks, heres the link http://cgi.ebay.com/ebaymotors/Maxim...spagenameZWDVW
and one more question, if my knock sensor is bad and is pulling timing and such, and upgrading to a higher octane do you think i should be able to gain some time at the dragstrip? I havent been sicne my catbacks, underdrive pulley, shortthrow shifter. I went when i had headers, gutted cats, removed resonator and an ebay can and i only ran a 15.2 do u think that could be improved with the new knock? besides the new parts? thanks alot - cory d
Old May 27, 2008 | 05:27 PM
pmohr's Avatar
No more Maximas...
The cheap eBay ones are fine, IIRC there are no aftermarket companies making the VQ knock sensor. They should all be dealer parts, pretty much.
Got an eBay one for ~$45 shipped a long time ago, works fine
Don't bother trying to estimate ETs based on replacing parts, you'll rarely be right. Replace it, run, see what happens.
Old May 27, 2008 | 05:51 PM
93altima's Avatar
Turbo 4th Gen
i too have an ebay ks works fine for me too
Old May 27, 2008 | 06:35 PM
maxx0831's Avatar
yup same, I bought mine for oem ks 65 bucks shipped and it was on ebay.
Old May 27, 2008 | 08:42 PM
jmedeir1's Avatar
word.. ebay has some reliable parts, and some not so reliable parts.. :/
Old May 28, 2008 | 09:09 AM
thanks alot guys, im deff. buying one then ... one more question i know its a pain in the *** to install n **** and me and my freind are going to do it he "claims" he's done it before but idk, so my question is there anything u can screw up by doing this yourself?
Old May 28, 2008 | 10:20 AM
bigtimemax's Avatar
I also purchased an ebay Knock Sensor works fine for me. I was able to install the sensor myself but I put it on upside down and had to flip it around. What a pain!
Old May 28, 2008 | 11:01 AM
koolseven's Avatar
I bought a cheap ks from ebay and installed it mysellf, is not an easy job but it you can do it, just disconnect the battery and you should be fine.
Old Jun 25, 2008 | 01:04 PM
80kbrake's Avatar
Anyone have a step by step direction to replace knock sensor? I can't even see it on my 99 SE. Thanks in advance.
Old Jun 25, 2008 | 01:18 PM
kzoosho's Avatar
I did my ks when i replaced my injectors other wise it still wouldnt be done.
Old Jul 12, 2008 | 11:05 AM
sergiovv's Avatar
i bougth ks on ebay and it cleared the code though performance is the same nothing changed at all. i am happy i didnt bought it at autozone by 138.00 i saved like 95.00.
Old Jul 12, 2008 | 11:23 AM
hornepirate's Avatar
I bought the cheap $40 one on ebay and it works just fine....while your doing it you might wanna change the harness but make sure its your knock sensor....it can be a PIA to replace the thing
Old Jul 12, 2008 | 01:56 PM
KyleFort32's Avatar
why are the struts so much cheaper on ebay?
Old Jul 12, 2008 | 03:10 PM
modenaf1's Avatar
I bought an Ebay KS as well, works great. It is a PITA to install though, I definitely recommend a universal joint, socket extenders, a lot of patience, and the expectation that you will get blood all over your block and LIM.
Old Jul 12, 2008 | 08:58 PM
internetautomar's Avatar
mod or sell?
Lack of warranty in many cases
Lack of overhead by the seller.
Greed.
Old Jul 12, 2008 | 09:52 PM
runyun972's Avatar
There's a person on eBay that sells OEM knock sensors
$52 shipped buy it now. You should get it since it's only a few bucks more
Old Jul 13, 2008 | 05:45 PM
Turbobink's Avatar
it's not a bad job at all guys...
the swivel/u-joint adapter is a must as are a couple, maybe even three, extensions.
just remove the upper air box and the air intake tube and you can get to it just fine.
Old Jul 14, 2008 | 05:08 PM
omoran2958's Avatar
i just had mine replaced not to long ago, $167 for the knock senser and $170 for labor.what a pain for my wallet...
Old Jul 14, 2008 | 06:31 PM
sergiovv's Avatar
but you did not get any bleeding hands , like i did,
$40.00 from an ebay sensor and 3 scratches in hands plus 30 minutes i spend doing it
Old Jul 16, 2008 | 12:21 PM
omoran2958's Avatar
car runs perfect know!!!!! 110544miles on my 97 max and gets 280 city driving and 350 highway on a full tank of gas.......
Old Jul 16, 2008 | 12:24 PM
Jamaha80
Wow, you really got bent over!
Old Jul 16, 2008 | 12:40 PM
gartman's Avatar
Car was throwing knock sensor, egrc solenoid and rear o2 codes.
So after some research decided to go with the knock sensor first, got one from ebay 55 shipped because dealer want 165 for part and close to 200 for labor. OUCH!
I bought the car in this condition, and it seemed to run fine, had enough power, seemed a little bit thirsty on gas but no biggie.
Buddy of mine put in the knock sensor and i was shocked the difference it made, my fuel economy is up, car seems alot more peppy.
And the egrc solenoid code went away with it?!? but still get the o2.
Ebay and this site saved me some cash.
Old Jul 16, 2008 | 04:29 PM
Kevlo911's Avatar
Kevlo for President
No more KNOCK SENSOR THREADS. We have 104853984593959 of them
kjlouis
Nov 24, 2018 06:09 AM
Slamrod
Sep 3, 2015 07:38 PM
raffivegas
Aug 23, 2015 09:54 PM
doobadoo
Aug 15, 2015 06:43 PM
