tranny leaking? ***PICS***
Old May 27, 2008 | 07:56 PM
G4nismo's Avatar
found some leaking in this area:
is that just the a/t tranny fluid leaking?
why is it doing that? do i need to change out some kind of gasket or what?
Old May 27, 2008 | 08:49 PM
f550maranello2's Avatar
thats ur rear main leaking like a ****...
Old May 27, 2008 | 09:01 PM
G4nismo's Avatar
how do i fix it?
Old May 27, 2008 | 09:05 PM
well... u need to drop the trans... the engine mounts with the cross member... the bottom and top oilpans...
installation is reverse of removal..
basically a weekend job... big pain in the ***
Old May 27, 2008 | 09:14 PM
mevjen's Avatar
The self-oil changing max
^^ I laughed.
Old May 28, 2008 | 05:03 AM
Turbobink's Avatar
Rear Main Seal... looks like it's leaking and has been leaking pretty good.
Here's what you gotta do: http://forums.maxima.org/showthread.php?t=562190
Old May 28, 2008 | 06:37 AM
G4nismo's Avatar
man i can already see a shop charging me an arm and a leg for this....
Old May 28, 2008 | 06:49 AM
G4nismo's Avatar
got a quote from one shop. ballpark ~ $1000.
not paying, nor have the money to repair that.
besides those leak stop additives which really don't work well,
what other remedies can i use to help this? any recommendation of specific oil?
should i use heavier weight? right now i'm running synthetic, 10w-30 i think.
Old May 28, 2008 | 07:28 AM
Snypa's Avatar
i think i see it too.
Old May 28, 2008 | 08:12 AM
Turbobink's Avatar
besides those leak stop additives which really don't work well, what other remedies can i use to help this? any recommendation of specific oil? should i use heavier weight? right now i'm running synthetic, 10w-30 i think.
Not really a whole lot will fix it aside from replacement. I would not use any type of additive. Maybe you could try one of those high mileage motor oils and see if that helps at all.
Keep checking around, I know you'll be able to get it replaced for less than a $grand$. I got mine done for $770, which I understand still might be a little bit high.
For now, just keep the area real clean so you can keep an eye on the severity of the leak and keep an eye on your oil level. Provided you can live with oil droppings you can drive with this condition for quite sometime as long as you monitor the seal for a catastrophic failure... at some point, and it's just a matter of time, your gonna have to have the seal replaced though... so start saving.
Old May 28, 2008 | 12:16 PM
G4nismo's Avatar
i hear yah. i still need to replace my upper and lower VC gasket. but i will clean the area, see if it'll improve and what not. i prob won't be able to fix this till maybe next summer...
Old Jun 2, 2008 | 05:58 PM
black_maxed95's Avatar
it may be an axle seal...if it is its a hundred times easier to fix.
IIRC if youre leaking tranny fluid its the axle seal, if youre leaking engine oil its the rear main seal.
most likely rear main seal tho.
ya a grand is too much. bring it to me up in wisconsin and ill do it for $200, plus cost of parts
Ive dropped my tranny before and yes its a *****, but better than paying $1000.
Old Jun 2, 2008 | 07:09 PM
G4nismo's Avatar
you want me to drive up to wisconsin!? that like $1000 in gas right there
why don't you move down to SC where its bright, sunny, and all the hot girls are and then i'll pay you $200 to fix it
Old Jun 2, 2008 | 09:00 PM
Fr33way™'s Avatar
Wild for Width
Fck that, for that price throw another VQ in.
Old Jun 2, 2008 | 10:14 PM
maxstillen83's Avatar
where are located, I just did it on mine, I could give you a good deal
Old Jun 2, 2008 | 10:50 PM
t6378tp's Avatar
Turbo 3.5
smell the leaky fluid 1st before you go off getting idea's about the cost. if it's oil clean the area and make sure it's not coming from up top and if it's gear oil do the same and trace it down
and like the other orger said for a grand I'd just drop in another engine less your's is fairly new
Old Jun 3, 2008 | 06:01 AM
G4nismo's Avatar
vq30 or 35?
Old Jun 3, 2008 | 06:02 AM
G4nismo's Avatar
south cacalakee
Old Jun 3, 2008 | 07:09 AM
MaxFanatik's Avatar
mine looked like that and it was a bolt came loose from the top... id wipe ur whole tranny off with all purpose cleaner and really see where the leak is comin from...
how bad are your oil puddles onthe ground after a night of standing?
Old Jun 3, 2008 | 07:20 AM
angelmaxima's Avatar
Im also leaking tranny fluid, my estimate from the shop was also 1000.
Im just keeping it clean and riding smart, and it will last me until it starts slipping.
It catches on without a problem now, hopefully by the time it starts slippin in the future, I will have saved enough to throw a G to the side and get a 5 spd
Old Jun 3, 2008 | 10:27 AM
G4nismo's Avatar
it doesn't really drip. i never noticed any oil puddles
Old Jun 3, 2008 | 10:43 AM
RacerX1320's Avatar
<---a sad yet deff probable alternative.
Old Jun 3, 2008 | 12:27 PM
MaxFanatik's Avatar
i know trannies sweat, mine sweats so if u never took a look at it it just built up over time.
Like i said clean it offff and see if its gonna be really wet the next day.
my friend zshopa from the .org he had the owrst tranny luck every he repalced them 3 times... if urs is not dripping it than it cant be anythign to bad but like i said whipe it down clean it good and keep an eye on it.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Socalstillen
Sep 20, 2015 11:46 PM
