Raising rear end..
Old May 28, 2008 | 08:48 PM
f550maranello2's Avatar
Raising rear end..
So like many people i have subs in the trunk... and i have stock springs with illumina struts... i dont like the way the rear sags.. is there any spacer or anything that can be inserted there to raise it up?
Old May 28, 2008 | 10:14 PM
Maxima_Joe's Avatar
4th Gen Parts King
You were in auto and swapped to a manual correct? Are you still using the automatic springs? If so your only option is to use manual front springs to drop the front to level the car out.
Old May 29, 2008 | 04:56 AM
ah crap.. wrong forum... this was supposed to be in 4th gen... Mods please move..
anywho.. i did swap to manual springs.. the front is the same height still...
its the back that sucks.
Old May 29, 2008 | 06:45 AM
udienow's Avatar
put lowering springs in front only.
Old May 29, 2008 | 06:51 AM
Kevlo911's Avatar
Kevlo for President
I assume you could install longer bolts on the rear strut mount and get a 1/2in spacer made that is the same shape of the rear strut mount
Old May 29, 2008 | 07:49 AM
Turbobink's Avatar
Air shocks...
Old May 29, 2008 | 02:24 PM
alicious's Avatar
the org...not what it was
...interesting place the 4th gen forums are
Old May 29, 2008 | 03:35 PM
rxm6's Avatar
just a thought, but how bout purchasing a set of touring springs from an i30t? they are pretty damn tall, and before i lowered my car i could go mudding.
Old May 29, 2008 | 04:18 PM
Maxima_Joe's Avatar
4th Gen Parts King
How much of a sag is there in the rear?
Are you sure the front springs were manual springs?
They should have lowered the front 1/2 inch making the car look level.
Old May 29, 2008 | 10:40 PM
tallkid2201's Avatar
just get some h techs, they are as close to stock feel as you can get and youll still look lowered....because you are. i have a system in my car and it actually makes the back and front look perfecttttttttt.
only 175 for em
Old May 30, 2008 | 05:15 AM
j2b4osan's Avatar
they make rubber spacers you can squeeze into the springs. People use them to cheaply raise trucks. I'm not sure how well the would fit on max springs but its worth a shot there cheap and sold at most autopart stores
Old May 30, 2008 | 06:03 AM
heres the thing guys.... when i changed the rear struts to illuminas, i didnt even have to compress the damn spring... is that normal
Old May 30, 2008 | 08:00 AM
rxm6's Avatar
^no
Old May 30, 2008 | 08:07 AM
VTonmymind's Avatar
Mmm, fresh lobster
a little OT, how do you like the ride with the Illumina's and the stock springs? Significantly better than with the stock struts?
Just curious because I was wanting to do the same thing. Keep the stock springs and just add the Illumina's.
thanx
Oh and you could always add some Koni yellows to the back. I believe they have a raisable perch.
Old May 30, 2008 | 11:55 AM
JEXTEL's Avatar
I have 400+ lbs of audio stuff bro
my rear end sags like no other BUT i installed KYB gr2 and maxspeed springs in the front only!
Im in the works of doing another system w/ 5 batteries(66lbs each), 3 12's(52lbs each), 6.8cu ft box(birch wood tryin to save wieght..lol) 5 amps, and the list goes on but i have found the solution with rubber spacer things from ebay...they are a 1.5" rasier but in my case that will be perfect with all this stuff camped in the trunk..in your case i you prolly can get smaller one..
http://cgi.ebay.com/ebaymotors/ws/eB...m=330231467862
Old May 30, 2008 | 03:12 PM
4DSCDriver's Avatar
That would be a good way to go. Replacing the springs couldn;t hurt and you could probably call around and find a set pretty cheap.
Are you shocks adjusted to thier stiffest setting?
Old May 31, 2008 | 05:09 AM
njmaxseltd's Avatar
It's called gravity and it keeps us planted here on mother earth.
As some have mentioned, put a set of lowering springs up front, I would recommend H&R's. Leave the rear alone. H&R's ride the best so you'll likely have a nice looking and very nice riding car set up that way.
Good luck.
Old May 31, 2008 | 05:40 AM
97SMG's Avatar
....... as mentioned not normal......Springs should have had lots of tension.
Old May 31, 2008 | 07:02 AM
maximized98's Avatar
Addicted to the Org
You need a fricken suv with all of that!!!!! Your mpg and performance must suffer
Old May 31, 2008 | 10:59 AM
That has nothing to do with how low the ride sits..
Old May 31, 2008 | 11:04 AM
SO i believe that i might have figured out a solution.. i went to advance autoparts this morning and got some coil spring boosters..
so far it looks great and rides great.. hope it works
Old May 31, 2008 | 12:12 PM
Morpheus2010's Avatar
Well i have a question myself. I want to drop the front of my maxima about 1in cause my back sags too from my 15" sub. I have illumnia with stock springs on 20"s please help
p.s. I want to keep my ride smooth and soft. I hate stiff. I have my old H&R sport springs, in my garages still, that i took off just to install the 20"s
Old May 31, 2008 | 01:41 PM
y not raise the back like i did..... it cost me 5 bucks
Old May 31, 2008 | 09:25 PM
JEXTEL's Avatar
yea i know but for now the max will do..lol 13mpg FTMFL
Just say thank you Jextel..lol
Old Jun 1, 2008 | 09:15 AM
99grnmaxgxe's Avatar
My friend bought those spring spacers at Pepboys for his Legend when he got his 20"s, still rubs though
Old Jun 1, 2008 | 11:24 AM
maximase86's Avatar
I love lamp.
Does it affect the ride any? Do you have some before and after pics? I'm dealing with the same sagging problem. Seems to always happen with any springs that were used on the car.
S
Old Jun 1, 2008 | 01:19 PM
well i drove with it for like 50 miles today... highway and city.. it drives GREAT.. it seems to handle and ride a lot better than before
Old Jun 2, 2008 | 12:44 PM
Kevlo911's Avatar
Kevlo for President
Any pics of them installed? how much did it raise it by?
I might put these on my H&R in the rear so I don't have to put some SE springs in the rear
Old Jun 2, 2008 | 09:14 PM
Fr33way™'s Avatar
Wild for Width
I would imagine that that artificially increases spring rate.
Let us know after a couple hundred miles how they are holding up.
Old Jun 2, 2008 | 09:40 PM
yea its a pretty red neck thing to do but like i said it rose the car about 2 inches... before it was WAY too low i had people in the back seat and it looked like the wheels were gonna rub...
Old Jun 3, 2008 | 08:29 AM
maximase86's Avatar
I love lamp.
Bump for pics!
Old Jun 3, 2008 | 09:18 AM
JEXTEL's Avatar
you sayin afer time they should give out?
Old Jun 3, 2008 | 12:24 PM
ptatohed's Avatar
Licensed to Spell
You answered your own question, that's what I was going to recommend.
Old Jun 3, 2008 | 01:26 PM
hot_wax_tree's Avatar
really I am surprised so little of you have heard of spring spacers. I have two sets in the front and back of my SE-R. the best one's that I found are the ones that are a complete circle. the little square one's that he got are the not bad kind IMO because they compress but I cnt tell if thos are rubber or not.
Yes they do make the ride a bit more stiff, but that is if their in the front.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
