5th gen mirrors install, need help with base
Old May 28, 2008 | 12:30 PM
Kadantsev's Avatar
Searched, but didn't find anything useful.
I recently purchased an A33 Cefiro power folding mirrors (You can see the silver mirror in my sig). Why? Well, to be different, why else... And of course different I got. Now I need to manufacture a new mirror base. Has this been done before? What materials were used? Thanks!
Old May 28, 2008 | 03:36 PM
2da mizzax's Avatar
why not some A32 power folding mirrors instead? direct bolt on. (i know, too little too late).
Old May 28, 2008 | 06:23 PM
Kadantsev's Avatar
Ya... that would be nice, wouldn't it...
Anybody?
Old May 29, 2008 | 05:56 AM
Kadantsev's Avatar
bump?..
Old May 29, 2008 | 06:09 AM
2da mizzax's Avatar
I assume the mounting holes underneath the main housing are in a differen position/different amount? Have pics of the underside? Before I got my JDM Power Folders I completely disassembled my mirrors and if the mounting holes are the same (and the plug matches up) it should be swappable.
Is that a JDM mirror?
Old May 29, 2008 | 06:47 AM
Kadantsev's Avatar
It's original Nissan. I will have to do some drilling in the door brackets to make some new holes which won't be the problem. The problem is insulating the thing so it doesn't leak inside the door panels (which I think it does at the moment). And of course there's the cosmetic look issue on the outside.
I'll take some pics in the lunchtime.
Old May 29, 2008 | 06:54 AM
2da mizzax's Avatar
I meant the mounting holes on the swivel, not on the door itself. Maybe you can use the A32 mount with the A33 housing. FSM doesnt give a diagram and I deleted my Nissan fast so I cant get a pic of the armature.
Old May 29, 2008 | 07:01 AM
Kadantsev's Avatar
Oh I see... That's a good idea, I'll see if I can do that. Thanks!
Old May 29, 2008 | 01:11 PM
ptatohed's Avatar
Licensed to Spell
Why didn't you get the 4th gen. power folding mirrors? Why is there an Infiniti badge on your grill??
Old May 29, 2008 | 03:02 PM
Kadantsev's Avatar
Why do birds fly? j/k
It's kinda too late to get another set of mirrors.
Looks like I won't be able to use the same base. 4th gen is a really different bolt pattern from 5th.
Old May 29, 2008 | 04:15 PM
2da mizzax's Avatar
I figured as much. and when I took mine apart, the base is one solid piece. Could always sell them and get the 4th genners. You go the OEM switch right?
Old May 29, 2008 | 04:31 PM
Kadantsev's Avatar
yup...that I do
Old May 29, 2008 | 04:43 PM
tyler5619's Avatar
seriously, why the infiniti badge? i30's put nissan in places to emulate a Cefiro, never heard of someone emulating an infiniti, especially with OEM maxima front end...roflcopter
Old May 29, 2008 | 05:47 PM
gtr_rider's Avatar
192.168.1.1
I have a friend who installed 5.5 gen folding mirrors on his 4th gen, it required some modification but it looks great.
Snypa's Avatar
i use my hands.
Old May 29, 2008 | 05:56 PM
ptatohed's Avatar
Licensed to Spell
I know but my question was why didn't you get 4th gen. mirrors in the first place.
Old May 29, 2008 | 06:45 PM
Kadantsev's Avatar
Undying strive to be different... Probably it... And I got FX35 rims.
Uhha! Any way of getting more details? What did he do exactly?
Cause I got a really good deal on them and I never seen them so cheap ($120 with shipping to Canada)
Old May 29, 2008 | 08:54 PM
gtr_rider's Avatar
192.168.1.1
The base had to be shaved of course to make them fit, and then he used the OEM mirror switch from the overseas 2003 as well.
Old May 31, 2008 | 03:55 PM
2da mizzax's Avatar
Here is another problem you may run into. Not sure where you got yours from, but mine came straight from Japan which makes them almost completely non-functional. With the Right hand drive, I get to see the entire side of my car from the dirvers mirror and I get to see 3 lanes over from the passenger mirror. I havent taken the time to figure it out yet, but this weekend I'll see if it is the glass that needs to be switched back to USDM or the bracket inside. (Hoping it's the plastic bracket so I dont have to go get heated glass. Plus I think the JDM would give a wider viewing angle.)
Just curious, where in Canada?
Old May 31, 2008 | 07:17 PM
Kadantsev's Avatar
Toronto, ON.
Doesn't seem like that's a problem with these mirrors. I can adjust it so the view is the same as it would be with USDM. They are from Japan though. I had to modify the US 5th gen mirror shells and glue them into the mirror.
Old May 31, 2008 | 08:15 PM
2da mizzax's Avatar
strange. My shells were an exact fit. just the view that is different. In TO too.
Old Jun 1, 2008 | 08:16 AM
Kadantsev's Avatar
sweet
well, the fit was exact, the holes for the snap-ins were different so I had to cut them off with a dremel and glue the whole thing with super glue.
Old Jun 1, 2008 | 09:05 AM
2da mizzax's Avatar
pics
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
JRod28
Feb 4, 2016 11:07 AM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
