Replacing axle seal
Old May 28, 2008 | 03:07 PM
NewEngSurf's Avatar
Replacing axle seal
Hey guys my drivers side axle seal is leaking and I was reading up on how to install a new seal using either a large socket or a seal installer. Well I am having trouble getting the old one out. I was reading alot and everyone seemed to just "pop" there old one out. Any tips or tricks on how to get mine to pop out?
Old May 28, 2008 | 04:38 PM
alset2's Avatar
I just use a flat head screw diver and work the seal out .just be carful not to damage the case.but they also make a couple of differnt tools to remove seals that you can probably rent (or borrow if you have an autozone) that work real well.
Old May 28, 2008 | 04:47 PM
f550maranello2's Avatar
auto or manual???
Old May 28, 2008 | 05:02 PM
NewEngSurf's Avatar
manual
Old May 28, 2008 | 05:03 PM
KRRZ350's Avatar
Ruh Roh................
Old May 28, 2008 | 06:00 PM
deadmax96's Avatar
seal puller kit (thats what the guy at the counter called it) but its still APITA to take off for me it was. but you do need to be careful and take your time cause if the case does get stratched up real bad the seal wont sit right and well you will have the same problem and more....good luck man the force is strong in you!!!
keep us posted on how it goes for you
Old May 28, 2008 | 06:16 PM
KRRZ350's Avatar
He's still going to have the same problem and more............
Search. Leaky driverside axle seal on a manual.......... Yet to see one that wasn't caused by bad dif' bearings.......
Old May 28, 2008 | 06:24 PM
deadmax96's Avatar
Tools needed for driveside axle replacement-----type that into the search bar. IT will give you the info your looking for and some more. How bad is the leak??
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
carlosvq30
Aug 17, 2015 11:32 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
