Any known mods for the maxima that will allow us to keep acc mode on without keys?
Old May 29, 2008 | 06:59 AM
S1cTech's Avatar
As most of you know. Bmw and mercedes have been doing this for years, which is another reason why i love bmw, anyway i love nissan too and i heard most new cars including nissan will let you put on acc without keys. (aka stereo, windows, cig lighter to charge phone)
thats all i pretty much want to do. I know if ur good with dc electricity it will be no prob, but i really am not sure were to start and i dont want to rip apart my dash or ignition.
is there and easy way of going about this? i am decent in electricity so i can find my way with some instruction on where to start.
Old May 29, 2008 | 02:46 PM
darklegend06's Avatar
well you don't want to keep the car in acc all the time.
So you have to figure out how to put the car in acc when you want it to and not.
It seems like a cool idea, but someone with time needs to come up with a wiring diagram.
Old May 29, 2008 | 02:48 PM
One thing I can think of is a switch.....
an on/off switch
Look through the wiring diagram in the FSM to learn how the ignition switch works.
Old May 29, 2008 | 03:11 PM
twoconfusedants's Avatar
and be careful not to end up w/ a dead battery...
Old May 29, 2008 | 03:13 PM
bigpulve+'s Avatar
put key into ignition, turn key too acc position...
Why teh hail does it matter?
Old May 29, 2008 | 03:40 PM
RA030726's Avatar
I'm nutty for Nissans
All wires are at the ignition switch.
Tap into, but dont cut, the 12v+ battery wire , its WHITE/RED to WHITE/PURPLE, connect to pin 87 and 86 on both relays.
Tap into the 2 ACC wires, again dont cut them, one is BLUE to WHITE/BLUE and the other is RED/YELLOW to RED . Connect one of the ACC wires to pin 30 on one relay and connect the other ACC wire to pin 30 on the other relay.
Mount your switch, connect one side of it to ground, then connect the other side of the switch to both relays pin 86.
That should work as the key would in the ACC position, but it wont power all things. I think you'd have to add another relay to power the ignition wire to get the windows to work. That wire is BLACK/WHITE to BLACK/RED, which gets wired up like the ACC wires.
Old May 29, 2008 | 03:41 PM
S1cTech's Avatar
well... lets see... it matters for 2 reasons.
1. i would like it stay in acc mode so i can charge say a fone or gps while i run in a store or go shopping and not worry about my car having its keys inside the ignition to get stolen or locked in.
2. Wouldnt it be nice to be able to put ur windows down or stereo on without having to worry about the keys or better yet going outside and just cranking the system while u wash ur car with the door closed and not have (if u have it like me) the alarm lock ur doors on you automaticly?
o and another reason is.. i hate how i have to put the car in pre-ignition mode to open any window or sunroof. It just hurts more battery and pressurizes ur fuel pump when you dont need too, which can cause faster failure, keeping pressure on the lines when you dont have to which could cause issues. There are lots of reasons.
Old May 29, 2008 | 06:31 PM
arrocha87's Avatar
id like to see the mod so everytn has power when u turn off the car until u open the door. Alot of new cars are like that...
Old May 30, 2008 | 02:42 AM
S1cTech's Avatar
yah most newer fords are like that. its like that in my company car 2005 ford escape.
scutmud
Aug 16, 2018 10:56 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
ah2002
Mar 9, 2016 01:42 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Tommy6905
Aug 14, 2015 11:54 AM
