air con problem
Old Jun 2, 2008 | 11:53 AM
clive's Avatar
100% chingon
air con problem
I have a 96 with the climate control. Here, the temp often gets to 40C in the summer or even more, so a bad aircon is horrible horrible horrible...
What's happening is that I start the car, with the aircon set to auto, usually 72F. I drive off and after a couple of minutes it is blowing nice and cold. But then, after about 5 minutes, it 'fades' - doesnt stop working completely but it is nowhere near good enough. Then, if I am on a longer journey, after about 20 minutes it usually starts working great again and will keep working great until the end of the journey. Switching to manual fan speed makes no difference. The rad fans do come on when I switch the AC on.
I have had the pressure of the refrigerant checked and it is full. No leaks. Also had the evap valve assembly changed. I also changed the climate control unit inside the car in case it was that. Can't think of what to do next?
Old Jun 2, 2008 | 06:45 PM
2da mizzax's Avatar
Originally Posted by skyisthelimit336
car might just be old. After a while things just stop working
someone please ban this guy.
Old Jun 3, 2008 | 02:18 AM
cedric's Avatar
It could be the expansion valve in the evaporator getting stuck.
It can the cause the evaporator to freeze up (air volume being pumped out of the vents will reduce) or it can cause the evaporator to heat up which means you wont be getting cold air.
If this is the case it will have to be replaced.
Old Jun 3, 2008 | 03:41 AM
alset2's Avatar
Do you have access to some gauges?? if so the next step would be doing some trouble shooting.
Old Jun 4, 2008 | 12:44 PM
clive's Avatar
100% chingon
Don't have the right type of gauges unfortunately. Think I'll have to try a different air con guy. It's got to the point where I'm thinking of changing the car! Maybe it is the evap valve again like the previous message suggested. Or maybe the pressure switch is sticking, have to check that, if it is then the compressor will be cycling. So if the compressor is not cycling it should be the evap valve I guess.
Old Jun 4, 2008 | 01:00 PM
95maxdvt
me too me too
same prob here read the top off how to but i know i did not overcharge only used 1 can seems it would have decreased in temp a lil tho
Mar 12, 2020 12:06 AM
Smackasmith
Feb 1, 2016 12:40 AM
thenewguyy
Sep 12, 2015 11:12 AM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
