Where Oh Where is the whole in my firewall?
Old Nov 4, 2001 | 07:41 PM
MaximaMan's Avatar
I'm trying to locate a whole through my firewall...
I do'nt really want to drill a hole, and right now i'm running my switch for my neon kit down the door and in the side through there...
i want to know where the main hole is for all the main cables n'stuff that has to go into the cabin! Thanx for teh help!
B
Old Nov 4, 2001 | 07:43 PM
tifosiv122's Avatar
Re: Where Oh Where is the whole in my firewall?
B
I guess the neon kit is no longer in the mail! What kit did you get. After its installed, let us know how you like it.
Thanks,
Erik
Old Nov 4, 2001 | 07:44 PM
MaximaMan's Avatar
one more thang...
i didn't relaly feel like searching...but how can i get to the bulbs behind my dash...somoen posted directions on how to do it along time ago..( i switched my bulbs...but now they've faded and are getting replaced) if someone wnats to point me in that direction that'd be very useful too!
Old Nov 4, 2001 | 07:47 PM
thebigsadler's Avatar
Re: one more thang...
there are 3 pre drilled holes. One is for the clutch pedal if you have an auto.. which you dont. the other two are on the sides and lead into the inner fender well. If you take of your tire and take all of the inner fender plastic out you should see the whole and follow it to the inside of the car.. those are the only predrilled holes.
Old Nov 4, 2001 | 07:48 PM
Dahnryman's Avatar
the hole is
right above the gas pedal about 10 inches ...i think ...it just a groumont
Old Nov 4, 2001 | 08:19 PM
Max4U's Avatar
Its right around by where the gas filter is, you will see like a peice of (starfoam) thingy covering it.
Old Nov 4, 2001 | 08:29 PM
dashingMax's Avatar
You are right about not drilling any holes through the firewall unless you have no other choice.
The best one to deal with is the rubber grommet which holds the cable that opens the hood from the lever from inside the car.
The best thing would be to cut a 45 degree slot and run your wires through. Make sure you seal the opening with some silicone glue after everything is done.
Good Luck
Old Nov 4, 2001 | 08:31 PM
ny96max's Avatar
just drill through the fire wall right at the clutch plate. Its punched into the metal behind a small rubber flap.
Old Nov 5, 2001 | 12:17 AM
puremax's Avatar
be careful not to drill through your brake booster for the hole!!!
I know all about it.
Old Nov 5, 2001 | 07:19 AM
dashingMax's Avatar
Pics
Any pics of your setup would be nice. I know it would be hard to take a picture of that part of the engine bay, but you never know.
Thx
Old Nov 5, 2001 | 10:39 AM
ptatohed's Avatar
Licensed to Spell
:o)
Forget that drilling and under the wheel well crap. There is an easy and convenient hole on the driver side. Imagine facing your engine bay (so that the driver side is on your right). It will be approx. 2' over and 1' down from the right. It will have a rubber plug in it. From the inside, you will see it high above the gas peddle. Good luck.
Old Nov 5, 2001 | 11:19 AM
dashingMax's Avatar
Re: :o)
Is this "rubber plug" removable? or will someone have to drill through it? Is it a grommet type seal?
Old Nov 5, 2001 | 11:36 AM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
Yes, it's removable. Trust me - I lost mine! I guess it's a grommet type seal. When I hear the word grommet, I imagine a rubber fitting that only covers the circumference and leaves an open hole. This is just like that but fills the hole. I imagine it will still fit back on if you don't add too many wires/thick wires but you will probably reach a point where it won't fit back in if you keep adding wires.
Old Nov 5, 2001 | 11:49 AM
dashingMax's Avatar
Re: Re: Re: :o)
So, if I drill a hole right through the center of this "rubber seal" (as you prefer) and run a about 2-3 18-gauge wires, I should be okay...right?
Old Nov 5, 2001 | 11:58 AM
ptatohed's Avatar
Licensed to Spell
Re: Re: Re: Re: :o)
Sure, that should work. What I would do is use an exacto to cut a slit, rather than making an open hole. Good luck.
Old Nov 5, 2001 | 06:02 PM
ny96max's Avatar
ummm WTF is goin on here?, its not a huge topic for discussion. Either find a gromet in the firewall or drill through where the clutchplate is, END OF STORY!
why would you drill through a rubber gromet?, make a slit in it for petes sake using a knife!
Old Nov 5, 2001 | 08:23 PM
ptatohed's Avatar
Licensed to Spell
Good grief NY96! Relax man, relax.
Old Nov 5, 2001 | 09:42 PM
ny96max's Avatar
i find it funny how there is so much confusion over finding or making a hole in the firewall for some neon lights, lol!
if he wanted to make life even easier all he would have to do is find an ignition wire off the steering column. Thats the place where i go for igntion when installing alarms,neons,strobes,amp turn on wires.
Old Nov 5, 2001 | 10:03 PM
frisky are we?
Old Nov 5, 2001 | 10:39 PM
dashingMax's Avatar
Hmmm... we are discussing about "finding or making a hole in the firewall" because this thread is about "Whole in my firewall"...
'nuff said
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
