Car wont start, something fried. Need help!
Old Jun 18, 2008 | 05:41 PM
MOHFpro90's Avatar
Ok, so tonight I was replacing my MAF and the 00 IACV gasket. I go to start my car at after all is done, it cranks, but doesnt start. Something is fried in the dash by the drivers left knee, just left of the gauge cluster are. I dont think its a fuse, cause when it fried, it buzzed and now smells, fuses pop and dont smell. As I said, it cranks, but doesnt turn over. Any ideas???
Old Jun 18, 2008 | 06:21 PM
G4nismo's Avatar
oh jeez kyle what did you do now?
how in the world did that happen? did you have any of the trim, buttons, etc taken out or were they all in place?
sounds like you shorted something out....
Old Jun 18, 2008 | 06:55 PM
speed racer's Avatar
when u did all this work did you remove the negative terminal from the battery. Could have fried a wire.
Old Jun 18, 2008 | 07:02 PM
Product_Of_Korea's Avatar
what ever it may be it doesnt sound healthy. frying wires is. i would start with the basics IE fuel and spark. and go from there. usually when there is a crank but no start up i would suspect one of two things. Crankshaft sensor or your fuel system. but i would lean more towards your fuel considering you have fried something by your drivers side. also i would double check the fuses underneath the hood if you havent already
95Serd
Sure it wasnt a relay under the hood on drivers side??
Isnt ignition relay in that box??
Old Jun 18, 2008 | 08:13 PM
if it were ignition relay i dont think it would turn over? but i could be wrong
Old Jun 18, 2008 | 09:38 PM
MOHFpro90's Avatar
Battery was connected. Although it should have been disconnected, disconnecting the MAF and IACV would not cause any harm. So dont worry about that.
Relays pop. Fuses pop. Neither buzz. Also the smell is fried silicon NOT fried wires.
The sound came from the far left dash area. The smell is inside the car.
Doesn anyone know if there is some sort of ignition control module or something similar behind the dash?
Old Jun 18, 2008 | 10:16 PM
Snypa's Avatar
only one way to find out.Why not check where you saw the flash/smoke/whatevr. Did you atleast check the area.?
Old Jun 19, 2008 | 04:58 AM
Kazoo's Avatar
There is a fuel relay in the kick panel by the left door behind a metal cover. Check that relay out. Actually there are two of them. I think its the one on the left side. See if that one has fried.
John
Old Jun 19, 2008 | 08:11 AM
MOHFpro90's Avatar
Snypa, I would check there if the sound I heard wasnt buried in the dash.
Kazoo. Relays dont buzz. They pop.
Old Jun 19, 2008 | 08:21 AM
maximase86's Avatar
I love lamp.
Does the fuel pump run for a second or two when you turn the ignition to on?
S
Old Jun 19, 2008 | 09:16 AM
MOHFpro90's Avatar
I checked all of the relays just in case. They are fine. All of the fuses in the kick panel are fine too.
Sarin, I can not hear the fuel pump making any noise, however I do hear a buzzing sound right in front of the starter. Will the fuel pump prime if the lines already have pressure?
Old Jun 19, 2008 | 02:25 PM
crash_landing's Avatar
crank sensor on my max caused it to not start... but your situation is different.
check connectors, they will have a different burning smell then the wires themselves... hope you have an ohm meter, wiring is a *****
Old Jun 19, 2008 | 04:21 PM
pmohr's Avatar
No more Maximas...
Yes, it will. There's no pressure sensor of any sort, so it'll prime as many times as you put the key in IGN.
Right in front of the starter...not really much there. Could it be sound from the starter solenoid or IACV?
I would pull the lower dash on the driver's side, there are a few relays that could be damaged left of the fuses (it's possible that they shorted internally and are burning up, seen it before...not fun). The buzzing sound could very well be something shorting between B+ and ground. After that, I'd probably drop that fuse/relay panel and check out the wiring behind it.
I believe the ignition relay there is for the ignition system, not the switch...but I could be wrong. Never really looked into it before.
I'd check to see if you're not getting fuel, or spark...narrow down what it is that's causing your no-start condition, that should in turn narrow down exactly what to look for.
Old Jun 19, 2008 | 04:34 PM
MOHFpro90's Avatar
crash_landing, I do have a multi meter, and yeah wiring is a *****.
pmohr, thanks for the help man.
The buzzing is not from the IACV. The sound is coming from below the front of the coolant log, by where the radiator hose is.
All of the fuses and 3 relays in the kick panel box are ok, I tested them, including the fuel pump relay which was hidden under the dash away from the other 3.
And by checking for spark/fuel, should I just pull a plug and tap the IGN? and then try to feel pressure in the fuel line?
Also, I have a new symptom. Today I tried to check codes, just to see if anything showed, and the CEL wouldn't even respond when I checked it with the screw driver. Also, the CEL does not come on when I turn the key to IGN.
Old Jun 19, 2008 | 04:39 PM
pmohr's Avatar
No more Maximas...
Pull a plug and a coil (or just the coil if you're got a known good plug laying around), put the plug in the coil and ground the threads of the plug...you should be able to see the spark on the tip of the plug.
For the fuel, best way really would be to pull one side of the rail up and see if they spray, but you could also do the one-man prime test; disconnect the battery, put the key in ignition, and hold the feed hose while reconnecting the battery. You should easily be able to feel it if it's priming, but that also doesn't rule out the injectors; they may not be passing fuel.
CEL issue is odd, first thing I'd check for is a blown bulb.
Old Jun 19, 2008 | 07:55 PM
MOHFpro90's Avatar
Thanks for your help. I will check for spark and fuel prime tomorrow. Would it be ok to just remove one injector and see if it sprays?
The bulb looks to be in good condition. I have half of my dash sitting on my bed... I will test tomorrow though.
Old Jun 19, 2008 | 08:03 PM
arrocha87's Avatar
probably dumb but is it possible u damaged ur ecu/computer watever its called?
Old Jun 19, 2008 | 08:07 PM
pmohr's Avatar
No more Maximas...
Yea, one injector will work just fine for the purposes of the test, assuming nothing weird is going on.
Old Jun 20, 2008 | 08:32 PM
MOHFpro90's Avatar
Ok, well I pulled the plugs. They smelt like gas. So I then grounded the threads, and cranked. No spark.
Any suggestions on where to go from here?
Old Jun 21, 2008 | 07:52 AM
MOHFpro90's Avatar
I checked this morning on the rear bank, still no spark. So both front and rear are not sparking.
I also pulled the front fuel rail up and checked for spray. I got nothing that I could see or feel.
What the hell is wrong?
Old Jun 21, 2008 | 08:57 AM
you wouldnt happen to have a spare ecu you could hook up would you?
Old Jun 21, 2008 | 01:44 PM
MOHFpro90's Avatar
I have a spare manual ecu, I hooked it up and it still didnt start. Also the CEL still didnt repond.
Old Jun 21, 2008 | 02:47 PM
cefiro80's Avatar
+1
Old Jun 21, 2008 | 02:58 PM
MOHFpro90's Avatar
I still have no spark or no fuel pressure. I found a blown fuse, but it didnt affect anything. Any ideas???
Old Jun 21, 2008 | 04:27 PM
KaneStyles's Avatar
alright im having almost the same problem.
i got a 1994 nissan maxima 3.0 sohc
i so ready to smash this car omg u have no idea.
1 the front 3 injectors = wiring somthing is wrong with it
2 the connector piece to the wiring harness is messed up i dont know why i check it with a tester light to see if its giving me power and ground Nope its not its only giving me 3 grounds i dont know why
so theres a problem somwhere in my engine wiring harness which sucks
also before that i was getting 2 grounds and 1 power after hooking up the fuel injectors still no start..... errrrrr...... now i take it off now and check the wiring clip its shows me 3 grounds ..... is there like a fuse i dont know about in the wiring harness or sumthing i have the complete car interor taken out i can see the the fuse box to the driver low side and big blue fues there too also to the passenger sige low feet thers a fuse box there too i dont know whats that for also i see my ecu and i see two red lights in it i dont know why if you live in new jersey in the sussex area can u come and give me a hand to fix this probelm my number is 862 228 8882 ask for kane
i really want this car to be fix its been 4 months trying to get this car fix so i can get a job....
Old Jun 21, 2008 | 06:19 PM
DrunkieTheBear's Avatar
Turbo'd Saab
dude there is a 3rd gen forum for your generation of car, MOHFPro90 has a serious problem and posts like these will not be answered here.
Edit: also please reread and edit/fix your gramar issues
Old Jun 21, 2008 | 07:48 PM
KaneStyles's Avatar
o **** my fault didnt see that
Old Jun 21, 2008 | 07:53 PM
Kevlo911's Avatar
Kevlo for President
Check the ECCM(or something similar) fuse under the hood.
Old Jun 21, 2008 | 08:16 PM
Turbo'd Saab
We did and it was blown and we replaced it and still no spark/fuel
Old Jun 21, 2008 | 08:52 PM
arrocha87's Avatar
ive been thinkn. wat about ur ignition switch? u do have power like when u turn ur key cuz u say it cranks? if it does couldnt it be from where it sends the signal to ur starter etc to start? i probably sound like a retard but if somebody understood wat i meant mayb itll help... have ya tried startn it with the ol' scewdriver to starter trick?
Old Jun 21, 2008 | 09:01 PM
MOHFpro90's Avatar
It does try to crank. But all that is working is the starter, no spark or fuel spray.
Old Jun 22, 2008 | 06:20 AM
Kevlo911's Avatar
Kevlo for President
CEL light come on in the ACC position?
Old Jun 22, 2008 | 07:30 AM
Turbo'd Saab
nope, I don't think he gets any response when he does the code check procedure
Old Jun 22, 2008 | 09:54 AM
MOHFpro90's Avatar
Kev, thanks for the help.
The CEL does not come on in the ACC position nor when I try to check the codes, as Dave said.
Old Jun 22, 2008 | 10:49 AM
Kevlo911's Avatar
Kevlo for President
ECM is not getting powered on.
Check ECU pin 24(R), to see if it gets power when the car is in ON and ACC (batt v)
Check ECU pin 80(W), to see if it gets power when the car is OFF (batt v)
ECU pin 67/72, see if it gets power in the ON and ACC position. (batt v)
ECU pin 4, should take a few seconds after you turn the key to start to off (batt v)
If 67/72 or pin 4 do not show voltage then check the ECCS relay and check if Fuse57 all the way to the relay has continuity(this will show if the wire from the fuse to the relay is shorted or not)
Old Jun 22, 2008 | 01:52 PM
Turbo'd Saab
I don't know why, but I have this gut feeling that is exactly whats wrong
Old Jun 22, 2008 | 02:15 PM
arrocha87's Avatar
keep talkn im taking notes! lol. i love reading threads u always learn something.
Old Jun 22, 2008 | 05:12 PM
MOHFpro90's Avatar
I tested ECU Pin 24, 67 and 72 and they didnt read any voltage on ACC/ON. ECU Pin 80 read voltage when the car was off.
What did you mean about pin 4?
The ECCS relay is ok as of yesterday when it operated in place of my fog light relay.
I will check the wire from fuse 57 to the relay.
Old Jun 22, 2008 | 05:32 PM
Kevlo911's Avatar
Kevlo for President
Pin 4 should be tested like pin 80, but you should try to start the car and then check it. I think it said it takes a few seconds.
