brake trouble
Old Jun 23, 2008 | 10:32 PM
blacmagic's Avatar
brake trouble
just installed new rotors and pads and after i drive for about 20 mins. or so car start to slow under full throttle(feels like brake are engaging on their own). thinking maybe i need to bleed the lines? or maybe da clutch?
Old Jun 23, 2008 | 10:53 PM
Snypa's Avatar
Try jacking the car and spinning the wheels by hand. Bleeding can be the fix as well.
Old Jun 24, 2008 | 05:34 AM
mastere954's Avatar
so u hit the gas hard and the car slows down??
Old Jun 24, 2008 | 06:44 AM
blacmagic's Avatar
yea and i get a weird odor like somethings burnin. i got a 5 speed and when i'm idled at the light it doesnt roll back it set there. its seems that i have to give it extra rpms to go.
Old Jun 24, 2008 | 08:22 AM
maximase86's Avatar
I love lamp.
Is it a metallic sort of order? Sounds like your brakes are dragging. When doing the brakes did you kink up one of the hoses? Did you have problems reassembling the caliper and reinstalling it? How do your brake hoses look (swollen at all).
Could be as simple a bleed...possibly could need a flush...possibly a bad brake hose...possible a bad caliper.
Old Jun 24, 2008 | 04:49 PM
nafddur's Avatar
Sounds just like you have a frozen caliper (common on Maximas). Maybe it's just coincidence it happened about the same time you did the other brake work.
Old Jun 24, 2008 | 05:14 PM
jojo98maxima
yes i had the same issue it turned out to be the caliper was bad i was also smelling that burnt smell
Old Jun 24, 2008 | 05:45 PM
fat_kid's Avatar
your ebrake could be sticking too, did you do both axels?
Old Jun 25, 2008 | 01:16 AM
maxx0831's Avatar
I had the same problem couple months ago. First off my rear calipers were seized in the back and in the front my driver side wheel was lock and was smoking everywhere. When i gotten it check, it was the sliding pins dat was seized. So check ya sliding pins or caliper. I paid the hard way.
Old Jun 25, 2008 | 01:43 AM
CMax03's Avatar
everytime I change may brake pads those pins are cleaned inspected and lubed with Hi-temp wheel bearing grease and I never have any problems...Not even on my old 86.5 hardbody p'up (324,000 miles)! also don't be afraid of using anti-seize on the threads of anything exposed to the elements!
Old Jun 25, 2008 | 03:27 AM
RacerX1320's Avatar
Both my rear calipers had issues recently. The left rear was seized and the right rear rotor was cracked. Deff take your wheel off and check them again.
Old Jun 25, 2008 | 07:48 AM
nafddur's Avatar
Rear calipers (those most prone to freezing up) are super easy to change, and only cost about $100 each from almost any auto parts store.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
