installed new motor, now problem with trans.....
Old Jun 24, 2008 | 07:40 PM
khantalha+'s Avatar
hi, have done a lot of swaps for people...but stuck with my own car...
i just got done installing a used low mile motor from a 96 5speed in my 98 auto... everything ran great till i fired it up...first it only ran with starter fluid otherwise died...double checked everything found out the fuel lines goin to the fuel rails were hooked up the opposite way fixed that and she started right up then let her idle for a long time then revved her up a lil and sounded perfect....installed new half shafts and stuff then took it for a spin... heres where the problems start... started sputtering and shaking a little bit as soon as i gave it some gas but shifted through every gear and was fine, then came to stop sign...started out sputtering and shaking again but no power this time looked like it was still in 3rd gear drove around for 5-10 mins and B**CH wont go in 4rth gear at all....took her home checked all the codes out here they are:
P0325 ----> 0304 (Knock sensor circuit malfunction)
P1336 ----> 1201 (http://forums.maxima.org/showthread....highlight=0201)
P0755 ----> 1302 (http://forums.maxima.org/showthread....highlight=1302)
P1105 ----> 0905 (http://forums.maxima.org/showthread.php?t=78486)
cleared them out and started it again, hard to start then boom started rite up, ran for another 10 mins...CEL back on again checked her again and here they are all four of these ***** back again.... kinda lost here so turned to good ole' org...
Thanksss
and sorry for the Long A$$ post...
Talha
Old Jun 24, 2008 | 07:43 PM
Kevlo911's Avatar
Kevlo for President
Sounds like one of the crank sensors is bad, that rid get rid of the crank code and the ignition code.
Are you auto?
khantalha+'s Avatar
yep its an Autotragic one
Old Jun 24, 2008 | 07:45 PM
khantalha+'s Avatar
also when cruising around 40 mph put it in 1st, 2nd and back to Drive and no change in trans ...
Old Jun 24, 2008 | 08:13 PM
Kevlo911's Avatar
Kevlo for President
Sounds like tranny harness not plugged in or its not grounded
Old Jun 25, 2008 | 12:46 PM
khantalha+'s Avatar
aite i ll go check thnx
Old Jun 25, 2008 | 03:27 PM
khantalha+'s Avatar
aite after 2 hrs of phucking around it came down to two things, the ground wire that goes next to the cooling line for the tranny was nt even hooked up and i saw a thin wire hanging there so figured that would be it.....thats for the ground wire, then decided to look at the crank position sensor (POS) and found out it had a big crack on its housing...so is that sensor junk now since it has a crack on it now or is it still reusable...????
tnx
Old Jun 25, 2008 | 03:34 PM
Kevlo911's Avatar
Kevlo for President
Get a new one, its not that expensive
Old Jun 25, 2008 | 05:45 PM
khantalha+'s Avatar
copy that bro will call the stealership tomorrow and c if they have one in stock, cuz mofoz dont have nothing , they always have to order them....
tnx i appreciate all ur help will let u know how everything went....
Old Jun 25, 2008 | 08:45 PM
f550maranello2's Avatar
get ready to pay big bucks at the stealer...
Old Jun 25, 2008 | 08:56 PM
cefiro80's Avatar
I dont think they are that bad hopefully it wont hurt the wallet that bad. Glad you seem to have nailed down the problems though
Old Jun 25, 2008 | 08:59 PM
Kevlo911's Avatar
Kevlo for President
Will be 50-80 at the dealer:
http://www.trademotion.com/partlocat...98&catalogid=1
Or get from here:
http://www.rockauto.com/catalog/x,ca...,parttype,7196
OR classifieds for oem and cheap
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
kirkhilles
Aug 8, 2015 10:53 AM
