Dropping tranny-maintenance suggestions
Old Jun 25, 2008 | 11:04 AM
black_maxed95's Avatar
So in a few weeks Im gonna be dropping the tranny on my 5spd (again ) to replace the timing ring. Somehow the timing ring got all messed up and now the car barely starts and has hesitations while driving. Anyways I would like suggestions on other things I can replace while Im down there. Alot are gonna say clutch, but I just did that in march and there are only about 30k on it so I wont do that. I was thinking more along the lines of doing the rear main seal for sure and im interested in other suggestions. Now is the oil pump in that area too? Should I replace that? My engine has 170k on it. Thanks.
Old Jun 25, 2008 | 11:23 AM
kzoosho's Avatar
All seals you can get to. Rear main a deff. I knwo i did while i had my tranny out. i think the oil pump is on the other side iirc.
Old Jun 25, 2008 | 11:32 AM
ok, ya im looking through the haynes and FSM and I realized the oil pump is on the other side.
Old Jun 25, 2008 | 02:40 PM
Product_Of_Korea's Avatar
+1 on rear main seal.
Old Jun 25, 2008 | 04:47 PM
dgeesaman's Avatar
Maintenance Monster
Call a transmission shop that does manual trannys and have them crack it open for a serious inspection. Refill with good gear oil.
RMS's leak but leaks don't explode and leave you stranded. If your tranny internals start going, and you don't catch it, you'll frag the whole thing. Spending $75 to have a pro poke around at it is a great investment.
Dave
Old Jun 25, 2008 | 07:29 PM
Nealoc187's Avatar
SLOW
after the nightmare that was my rear main seal replacement, I sure as **** wouldn't go doing one unless it were leaking. if it ain't broke, don't fix it is the saying that applies in this case.
Old Jul 2, 2008 | 09:42 AM
dgeesaman's Avatar
Maintenance Monster
Are you referring to the whole process of taking down the upper oil pan, or did something unusual make your situation worse than that?
Dave
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
maxima-junky
Oct 7, 2015 06:13 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
