EGR Codes
Old Jun 27, 2008 | 10:48 AM
btbrown's Avatar
EGR Codes
I have the following codes 1005 and 0302 both are EGR codes. 1005 states that it is EGRC Solenoid valve. Do you all know if the 1005 code could have triggered the 0302 since it is a basic code? I also would like to know if this code have gotten this code because of EGR valve gasket? All opinions are welcome.
Old Jun 27, 2008 | 02:08 PM
maximized98's Avatar
Addicted to the Org
the 0302 is a flow code. More than likely your egr pipe is clogged. The bigger pipe that goes from the intake manifold to the egr valve. The other code is a green sensor plug.
Old Jun 27, 2008 | 03:24 PM
knight71's Avatar
Replace the Solenoid valve and 03/02 should go away..if not check these threads..
http://forums.maxima.org/oldthread.php?t=350528
http://forums.maxima.org/oldthread.php?t=516825&page=2
http://forums.maxima.org/showthread.php?t=372440
Old Jun 28, 2008 | 02:36 PM
xlr8r's Avatar
Well, I'd test it first. Most of the solenoid valves can be tested by blowing through them while applying battery to the coil.
You can hear them click as well.
Old Jun 28, 2008 | 04:07 PM
btbrown's Avatar
Do you have a picture?
Old Jun 28, 2008 | 06:13 PM
Addicted to the Org
http://forums.maxima.org/4th-generat...oid-valve.html
That shows you what the egrc valve looks like. Your egr pipe is located on the far right top portion of the intake manifold and goes down into the egr valve.
http://forums.maxima.org/4th-generat...e-removal.html
Old Jul 5, 2008 | 06:58 PM
btbrown's Avatar
I notice that I did not have a pipe connected to my egr pipe. I am guessing that this could have caused the 0302. I have not had time to look and see just yet been on vacation. Do you think that the light gas fumes could be coming form this. Do you have a picture or a part number for the green sensor plug?
Old Jul 6, 2008 | 12:27 PM
knight71's Avatar
The pic and part # was already posted by Maximized..click on the link he provided!
Old Jul 10, 2008 | 09:02 AM
btbrown's Avatar
how do i fix the 1005 code
Old Jul 10, 2008 | 09:26 AM
Addicted to the Org
replace the sensor!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
See above posts^^^^^^^^^^^^^
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
