Shaving trunk keyhole help
My key cylinder has been messed up forever and i think somebody tried again becuz a couple of weeks ago it was missing, or maybe it flew off in the highway. Anyways, im pretty good with dents and sanding and ive used body filler before but ive never dealt with an actual hole. Do i need to weld a plate behind it and then just fill it and sand it? or is their another way?
any input is appreciated! thanks in advance guys!
i'm sure theres ways to half *** it but the right way to do it is to weld a filler plate over it (not behind it), grind down the welds, fill it (pull back the paint with a da first), prime/seal/paint it.
you cut a filler plate thats just smaller than the hole and try to make it sit flush or slightly sunken in. the reason you don't go behind is because your filler will be too thick, which will leave it prone to cracking/shrinking.
nothin particular... i think 16g is the most common for sheetmetal work but its been a while since i bought metal.
be careful with heat when you weld also. do a bunch of tacks with time to cool in between rather than running a bead. warped metal = more body work.
When Ptatohed has his keyhole filled in, I believe his brother tack welded a plate at the back side first, then proceeded pretty much like you suggested here.....
Good advice here. Ptatohed's brother (a body shop guy) told/taught us the same.
OK here is what you do. Go to the paint and body store and get something called cathair. Its like a bondo/fiberglass/resin mix. use that and its just as hard as welding a plate, and is very easy to sand within the first 1-2 or so, but after it sets up its hard as hell. It goes on just like bondo and is easy to pull. Good luck with it.
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
rbaker100
Sep 6, 2015 02:46 PM
