No start, No crank, Starter changed. HELP
Old Jul 6, 2008 | 01:45 PM
97PKIMVQ's Avatar
Ok, so I had my car parked at Target for about 30 minutes than when I return back to the car, it doesn't crank. Battery is fine. Starter is ok (replaced it last night). I'm all out of ideas. I can roll start my car. I tested the starter itself and works fine. I believe the ignition switch was changed with the last owner since I do have two keys one for IGN and one for my door.
Any idea??? I'm just fed up now. Any help would be great. Thanks
Old Jul 6, 2008 | 01:58 PM
B_Eaze's Avatar
Thats weird. Most likely ignition switch, i had a corroded one and it caused me all types of stress (in a Mercury, 1st car) R u sure battery's ok? Maybe you have a power drain somewhere? any codes?
Old Jul 6, 2008 | 02:27 PM
97PKIMVQ's Avatar
Batt is fine. No codes. I'm sure I don't have a power drain. When I try to crank it while the car is on I get an RPM drop which is normal due to all the current being drained by the starter. But I'm reading up on everyone elses issue and it seems that it could be the ignition switch. Is there a "how to" on the stickies somewhere? how much do they usually run for?
Old Jul 6, 2008 | 03:22 PM
B_Eaze's Avatar
Courtesy Parts $30
http://www.courtesyparts.com/Merchan...de=48750-IGNSW
Old Jul 7, 2008 | 10:39 AM
97PKIMVQ's Avatar
After reading all the other threads I tried to start the car about 30+ times in a certain way or w/ever .... nothing.
If it is not sending a signal for the starter to crank the motor is it the ignition switch?
Old Jul 7, 2008 | 01:08 PM
alset2's Avatar
maybe its the nuetral safety switch and/or relay.
cluthch switch if its a 5 speed
Old Jul 7, 2008 | 02:18 PM
Product_Of_Korea's Avatar
or the grounds are bad that go on the front bolts on the upper intake manifold
Old Jul 7, 2008 | 02:39 PM
DrTySOUFMaX23's Avatar
alternator maybe?? or the screws on the starter might be loose make sure to go back and tighten those suckers up coz that's what happened to me or take out the terminals off your battery and brush out the corrosion!
Old Jul 7, 2008 | 03:42 PM
97PKIMVQ's Avatar
EVERYTHING HAS BEEN TIGTENED WELL AND SECURLY. ALL GROUNDS ARE OK. STARTER IS NOT THE ISSUE. NIETHER IS ALTERNATOR.
What are the chances that it is the clutch switch?
How would I be able to test for this switch alone?
Is there a fuse that could be blown for my car?
MY CAR DOES NOT even ATTEMPT TO CRANK. I just flip the key and nothing.
BATTERY IS PERFECT!!! NO RUST!!!
Old Jul 7, 2008 | 03:56 PM
alset2's Avatar
well you can put a jumper in the clutch switch and see if it will start.
hey did you find any wierd pices of plastic laying on the floor board?? Im thinking may be the little plastic contact pad broke or fell out.
Old Jul 7, 2008 | 04:53 PM
97PKIMVQ's Avatar
Hmmm.... didn't know it had some type of contact pad. Let me check that.
Old Jul 8, 2008 | 11:21 AM
97PKIMVQ's Avatar
didnt find anything. still clueless.
is there a write up on the .org on how to replace the ignition switch?
Old Jul 8, 2008 | 01:31 PM
B_Eaze's Avatar
Did you ever check ignition switch, do a quick search on it if not. I think ignition switch
Old Jul 8, 2008 | 01:35 PM
B_Eaze's Avatar
your in luck bud
http://forums.maxima.org/4th-generat...on-switch.html
Old Jul 8, 2008 | 04:17 PM
97PKIMVQ's Avatar
THANKS. Really appreciate this.
Old Jul 8, 2008 | 05:16 PM
97PKIMVQ's Avatar
Purchased a brand new ignition switch for 55 at the dealership since i cannot wait. Going to install today after work... hopefully this corrects the issue.
Has anyone here at the .org corrected this issue where previous symptoms were where it will not start AT ALL even though you "jiggle" the key in IGN?
is there a reason why the ign switch fails out of no where?
it seems like there is usually a sign or warning that the switch is ready to fail.... if there is no warning sign should i still diagnose this problem as a possible ignition switch problem?
Old Jul 9, 2008 | 10:06 AM
97PKIMVQ's Avatar
So I finally sat there with a multimeter for a few hours last night and realized it was NOT the ignition switch. I looked and realized that some of my ignition switch wires on the male side was going to my aftermarket alarm system. Turns out the wires are loose on the relay... tightened those up and it cranked. WHEW talk about a sigh of relief when I heard my car fire up.
I can't return the IGN switch so now I spent $60 for a useless part. damnit. lol
thanks for the help everyone....
Old Jul 10, 2008 | 07:57 AM
TunerMaxima3000's Avatar
REF ---->>> http://forums.maxima.org/4th-generat...swer-help.html
Old May 29, 2009 | 12:17 AM
pepylepew1961's Avatar
i have experienced same problem with 96 , ign swt, relay ,,good batt & strt , any ideas?
Old May 29, 2009 | 12:21 AM
pmohr's Avatar
No more Maximas...
This thread is almost a year old.
Are you seriously not going to
  1. Take my advice in one of the other threads you posted in
  2. Post in the DAMN NEWBIE THREAD. Spreading your posts out over multiple threads is only going to HURT your diagnosis, not help.
It's not that damn hard to understand, Greg.
You keep on asking for responses, but you're obviously not reading a single damn one of them.
Old May 29, 2009 | 01:40 AM
thanks alot
thanks for smart %$&^ answer! youve been real helpful , loosen up dude
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
