Removed manifold; anythng I shld cnsider while I got this opened??
Old Jul 10, 2008 | 09:09 PM
Maximas's Avatar
2DA MAXX
I just removed the upper intake manifold in order to replace the valve cover gaskets & spark plug tube seals; one of the rear coilpacks had some oil on it and in the chamber.
I figured since it’s been such a pain to remove the manifold w/ all the tube disconnections and hard to reach bolts I wanted SUGGESTIONS from experienced diy-ers on what I should consider having done/cleaned/checked/replaced while I have this thing opened up.
The car is a 1996 max with 134,000miles.
Old Jul 10, 2008 | 09:30 PM
elemax's Avatar
The fuel filter is easier to get at now. you could send your fuel injectors in for servicing, I've always noticed a nice difference after I've sent mine in, you probably would too with 134k miles.
http://www.cruzinperformance.com/fuelinj.html
http://www.witchhunter.com/ <---- Ive used them several times, great service
Old Jul 10, 2008 | 09:52 PM
pmohr's Avatar
No more Maximas...
Your knock sensor wouldn't happen to need a replacement, would it? It's a mere 12 bolts away...
Old Jul 10, 2008 | 10:05 PM
Maximas's Avatar
2DA MAXX
Can the openings of the manifold (between the fuel injectors) be cleaned out with something? Right now it is black and wasn't sure if this was normal. Until I find the problem, it has been running a little lean or rich.
Old Jul 10, 2008 | 10:10 PM
If you do choose to have your fuel injectors professionally cleaned, you may want to consider these guys.
http://www.deatschwerks.com/catalog/
I bought my 555cc injectors from them.
Old Jul 10, 2008 | 10:16 PM
maxx0831's Avatar
how long does it take for them to clean and send back the injectors? I will probably do this later on down the road as well
Old Jul 11, 2008 | 08:30 AM
MOHFpro90's Avatar
I wouldn't bother. In about 6 months or so it is going to look the same way again.
As pmohr said, KS is easy...
Old Jul 11, 2008 | 08:37 AM
MDeezy's Avatar
Clean out the ports as well as you can and replace. The manifold also, if you wash it out you'll see how black it is in there.
Old Jul 11, 2008 | 01:34 PM
volodya84's Avatar
I would definitely do the knock sensor while youre at it, trust me you dont want to do it the hard way (I had to when my mechanic quoted me 500 dollars to do it)
Old Jul 11, 2008 | 01:35 PM
Aaron92SE's Avatar
NWP Engineering.com
Thermal Intake Spacers?
http://forums.maxima.org/group-deals...gineering.html
Old Jul 11, 2008 | 03:37 PM
internetautomar's Avatar
mod or sell?
Dam I got quoted $80 (labor only) and though it was too much
Old Jul 11, 2008 | 07:36 PM
Product_Of_Korea's Avatar
00vi
nah im j/k but i would clean out your egr tube if its looking bad
Old Jul 11, 2008 | 07:47 PM
MDeezy's Avatar
did that include f**kin his wife too?
jeeze
James92SE
142
Jan 2, 2024 09:23 AM
05RLS2
Nov 7, 2016 05:52 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
