Rotors
Old Jul 11, 2008 | 02:41 PM
LudaTej's Avatar
Rotors
so my maxi juss hit 130k miles and im thinkin its finally time to replace the stock suspension and brakes... ive been lookin around for cross-drilled/slotted rotors and found these generic brand rotors on ebay...
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
would these be any good or am i wasting my time considering these?? my other option is the powerstop brand...
http://cpwstore.carpartswholesale.co...9179+11920+833
i would get brembo ones but my budget is kinda tight right now... im tryin not to go over $250 for all four... i still have to buy calipers as well as shocks & springs...
Old Jul 11, 2008 | 02:49 PM
modenaf1's Avatar
If you have it narrowed down to those two, I would go with the powerstop brand. I do not recommend cross drilled rotors. There was an article posted on here a while back as to why they are not a good idea, but basically the cross drilled holes reduce the total amount of material capable of absorbing heat as well as crack easilly around the holes with high heat and stress.
The only advantage of cross drilling is 1.) to reduce unsprung weight 2.) help clear the rotor surface of dust water and debris, for example they are good in rally cars.
Old Jul 11, 2008 | 02:56 PM
LudaTej's Avatar
really?? i always thought cross-drilled were better than slotted... thats my fault for my lack of researching lol... okay so as of rite now im most likely going to buy the powerstops unless i see anything else better... thnx for the 2cents...
Old Jul 11, 2008 | 03:34 PM
internetautomar's Avatar
mod or sell?
the best option is blanks.
Old Jul 11, 2008 | 04:12 PM
LudaTej's Avatar
after doing some research on the "advanced performance" section it seems that most people feel blanks are the best option... guessing i should get those then huh??
Old Jul 12, 2008 | 08:45 PM
mod or sell?
yes
Old Jul 12, 2008 | 08:50 PM
WhiteA32's Avatar
Blanks FTW. They have the most surface area, so you can have the most stopping power.
Old Jul 12, 2008 | 09:44 PM
Slitfang's Avatar
YES. blanks give you the best stopping power and they will last you the longest. i cant tell you how many times ive heard stories of drilled/slotted rotors cracking after 1 1/2 - 2 years. i too am getting new Rotors and i think im going Brembo.
Old Jul 12, 2008 | 10:01 PM
MOHFpro90's Avatar
Proper cross drilled rotors aren't even drilled. They are cast with the holes. This greatly reduces the possibility of cracking. Only some serious overheating and extreme rapid cooling will crack them. Not to mention on our cars, you can run just fine with the hairline cracks you might get with them anyway. Your rotors wont shatter like they would on a car doing 180-60 in 4 seconds...
The surface area arguement is kinda bad too...youre gaining like 3% or something...so small that just braking technique can be better compensation...
Still, blanks are your best option for a daily driven maxima. Much cheaper and perform just as well.
Old Jul 13, 2008 | 08:07 AM
LudaTej's Avatar
thnx for all the information guys... i've decided to go wit blanks...
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
