Subwoofer mounting question
Hi -
I got a deal on an 8" tube subwoofer and a small alpine amp that I just couldn't pass up.
Now I need suggestions on the best way to mount the amp and subwoofer in the trunk.
I really want to keep access to the pass through hole and the spare tire.
I am thinking of mounting the amp on the underside of the rear deck and attaching some strapping points to the trunk floor and the rear firewall.
Any thoughts or suggestions???
Thanks!
Thanks!
well if you mount it there, get ready in about 6 month or less for you car o sound like a herd of horses trampling over a steel roof cause that thing will rattle your car silly if you mount it there...best to mount it on the floor honestly but thats just me
Oh, and you might get better responses here....
http://forums.maxima.org/audio-electronics-21/
yeah....mounting the amp upside down is a bad idea! heat has a tendency to rise and your amp will eventually fry! As far as the sub goes...if it is a bass tube (like the Bazooka tube) they sounds best when the sound is able to bounce or reverberate off of something. So in my opinion i would mount it with the woofer facing the back of your car and neer the trunk lid for optimal performance!
Straps would be to mount the tube.
Thanks for the info.
I didn't notice the audio forum since everything I do on here is in the 4th gen forum. I am going to go search there next.
I appreciate the tip about not mounting the amp to the underside of the rear deck. Also, CRiME is correct, the strap points are for the tube subwoofer.
The Frye
Sep 2, 2021 11:03 AM
