Need some help, cracked oil pan
Old Jul 23, 2008 | 06:48 PM
Graem's Avatar
Hey guys, I was just replacing my oil presure sender cause it was leaking and when i put the new one in the oil pan cracked. The threads broke and are now in 3 pieces.
What am I looking at. Do i have to pull the engine and get a whole new oil pan or can it be fixed somehow. help is appreciated.
thanks.
Also, wtb a new oil pan.
Old Jul 23, 2008 | 10:31 PM
Graem's Avatar
ok, my car is on ramps in the driveway and i would love some input.
exactly how deep did i get myself into it???
Old Jul 24, 2008 | 07:21 AM
mtrai760's Avatar
'Trynna' is not a word
You can replace the lower oil pan without removing the engine, it's not that hard.
Old Jul 24, 2008 | 07:25 AM
matty's Avatar
Purchase a new lower cover.
Old Jul 24, 2008 | 10:22 AM
CRiME's Avatar
oem ftw!
Would it be possible for you to take a picture of the damage? I might be reading it incorrectly, but when you say that the threads broke, which threads do you mean? Are you referring to the upper (aluminum) oil pan where the sending unit screws into ? If the problem is just that the lower oil pan somehow cracked, you can replace it without removing anything, as the above posters have mentioned. The FSM calls for liquid gasket alone, but Autozone sells a Felpro gasket for $8.
If the upper oil pan is somehow busted, then I can't really think of any other options besides pulling it and replacing, possibly with one from a junkyard. That's much more involved, however, and you have to remove your Y pipe, crossmember, and several other parts. The difficulty would obviously be multiplied if you're doing this on ramps. If you're interested in doing it yourself, the procedure is covered pretty well in the EM portion of the FSM. If you don't have the FSM, you can get it from here:
http://www.phatg20.net/component/opt...,select/id,28/
If you're unable to take a picture, maybe you can use this picture from motorvate to help point out exactly where the damage is, so other posters will be better able to assist:
Old Jul 24, 2008 | 11:55 AM
Graem's Avatar
the damage is where the oil pressure sender unit screws into the oil pan. This is on the upper aluminum oil pan beside the oil filter.
In the above picture its right where the wires are running into the oil pan.
Am I going to have to pull the engine to remove the upper oil pan?
Is there anywhere on line to purches a new or used one? I searched around and only found the lower oil pan for sale.
Old Jul 24, 2008 | 12:36 PM
CRiME's Avatar
oem ftw!
Yikes, that's the first time that I've ever heard of breakage in that part of the pan. I have to remember to be extra careful the next time I replace my OPSU You do not have to pull the engine to replace the upper pan. I strongly recommend checking out the FSM, as it outlines everything that you must do to remove it. You can buy the pan new from world parts express for $96, and they are great vendors of OEM parts.
http://www.worldpartsexpress.com/par...95&catalogid=1
Old Jul 24, 2008 | 12:53 PM
one_fast_max's Avatar
no you don't have to remove the engine. the oil pan really isn't too bad. just take your time and read up on it. don't lose the bolts! there's alot!
while your at it you oughta get a aftermarket y-pipe....if you don't already have one. check your engine mounts too
Old Jul 24, 2008 | 06:17 PM
pmohr's Avatar
No more Maximas...
I learned how fragile the upper pan was back in the day, when I tried to draw my trans onto the motor with the bellhousing bolts.
In retrospect, I should've stopped after I heard the first crack (or just not done it at all).
That piece is now sitting in my box at work, I might actually have it welded back on before I get my 5 speed in...
Old Jul 25, 2008 | 08:42 AM
Graem's Avatar
Originally Posted by Jamaha80
Cough-JB Weld-cough-cough....
JB wels and some silicon are looking like the easy way out.
Whats a reasonable price to have the oil pan removed and replaced by a shop?
Old Jul 25, 2008 | 10:29 PM
Graem's Avatar
here is a picture of the cracked threads. tell me what you think...
Old Jul 25, 2008 | 11:31 PM
matty's Avatar
Wow....thats horrible...I think if I was in that spot and didnt have alot invested in the vehicle, I would clean it really well with a degreaser, let it dry, JB weld the area and thread in a new sender into the wet JB weld. It will all dry and be fixed but not 100%.
Old Jul 26, 2008 | 12:01 PM
matty's Avatar
Also make sure the entire area is cleaned before you go and apply the JB weld and make you get NO JB on the end of the sensor.
Old Jul 28, 2008 | 08:57 AM
Graem's Avatar
So I put it all back together with JB, let it set for two days and filled the area in with some liquid gasket.
Fired the car back up again and Oil came pissing out.
Looks like I have to replace the pan after all, 500$ I didn't want to spend.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Andy29
Sep 29, 2015 05:32 AM
