No tail lights HELP
Old Aug 1, 2008 | 11:33 AM
bmaxedout's Avatar
No tail lights HELP
i have a 95 max, my tail lights are out!!! the fuse are not burnt out and have changed the bulbs still no lights, the brake lights turn signals work any one ever had this happen can you help me out
Old Aug 1, 2008 | 11:39 AM
It probably is the fuse, check it again. The fuse should be a 7.5
Old Aug 6, 2008 | 11:04 AM
bmaxedout's Avatar
update, changed all the bulbs and fuses again i have turn, brake, and reverse lights, still no tail lights or corner markers. I did notice in the engine bay that theres a corner light relay how can i test that to see if it is working? and does anyone know of a fuse inside the car that could be out?
Old Aug 6, 2008 | 11:10 AM
arrocha87's Avatar
yea u have the fuses under the driver side dash. ur cover should have a diagram of which fuse is for what.
Old Aug 6, 2008 | 11:13 AM
bmaxedout's Avatar
i don't have a cover with a diagram anyone know of where I can find a diagram? in pdf format
Old Aug 6, 2008 | 11:24 AM
arrocha87's Avatar
i cant find it in my FSM... sorry. i wont be home til midnight and ill take a pic of the cover if no one has posted.
Old Aug 6, 2008 | 11:36 AM
bmaxedout's Avatar
thank you so much this is driving me crazy!
Old Aug 6, 2008 | 11:52 AM
omoran2958's Avatar
its got to be the fuse!!!
Old Aug 6, 2008 | 12:58 PM
rex3001's Avatar
could also be that if someone owned the car before and messed around with any of the wiring on the tails, the wire to the brake light might not be making good contact anymore.... that was the case with me at least... had to solder them back together with one of those cold heat guns
Old Aug 7, 2008 | 07:03 AM
bmaxedout's Avatar
thanks for the suggestions i did trace the wires to make sure they are all intact and they are, so if anyone could post a pic of the fuse panel and post it i would appreciate it
Old Aug 7, 2008 | 08:14 AM
Nopike's Avatar
Check fuse #5 (7.5 amp) This is the fuse for the tail lamps. Take it out and take a good look. I believe it is located in the underdash fuse holder. That fuse holder has the fuse numbers molded into it you have to look closely.
Old Aug 7, 2008 | 08:26 AM
black_maxed95's Avatar
You say you have no corner lights either? It could be the switch inside the car is broken. But check the fuse and relay first.
Do your interior lights light up when you turn on the parking lights?
Old Aug 7, 2008 | 08:28 AM
Nopike's Avatar
When you are looking at the fuse box, Fuse #5 is in the left side row (5th one up?)
Old Aug 7, 2008 | 09:33 AM
arrocha87's Avatar
thats right. i tried taking a pic of it and even with my digital camera you cant make out the writing on the lid. sorry...
Old Aug 7, 2008 | 10:57 AM
bmaxedout's Avatar
thanks i'll go check that now can you look to see if theres a corner lamp fuse also?
Old Aug 7, 2008 | 10:58 AM
Maxima_Joe's Avatar
4th Gen Parts King
Old Aug 7, 2008 | 11:04 AM
bmaxedout's Avatar
thanks to all you that helped out! you guys rock!!!!
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
