Maxima starting problems
Old Aug 1, 2008 | 06:39 PM
maxman95's Avatar
My check engine light came on and it pulled the crankshaft sensor. my car has 155 on it and i was wondering do you think i need a starter or will just replacing the crankshaft sensor will do it....
Old Aug 1, 2008 | 06:53 PM
matty's Avatar
Well is it cranking at all ?? We need some more information on the problem
Old Aug 1, 2008 | 07:40 PM
maxman95's Avatar
it cranks after like 3 times and it starts right up
Old Aug 5, 2008 | 09:19 PM
maxman95's Avatar
should i change both... could anybody give me some info on what i should do thanks
Old Aug 5, 2008 | 09:36 PM
mista0406's Avatar
does it make any wierd screeching sound when you start it or is it a normal start?
Old Aug 5, 2008 | 09:50 PM
Spitzberg Beast's Avatar
If the CEL pulled the crankshaft sensor then i think you should change that first to avoid spending money on an unnecessary starter.
I had starting problems also, i got 170 on mine, my CEL pulled crankshaft sensor and camshaft sensor. I changed both and still had problems and my CEL stayed on. I also had to change my starter 3 times. Within a week of the 3rd starter my CEL disappeared and my car starts up much better now although it may still need work. I think i know what your going through. See what the others say, they may suggest differently.
Old Aug 5, 2008 | 10:13 PM
maxman95's Avatar
It doesnt make a screeching sound but when i put the key in i have to twist it and hold it for for like 3 seconds then it will start up it feels like it needs some help lol starting right up ....
Old Aug 5, 2008 | 10:18 PM
mista0406's Avatar
seems to me to be the starter but if you want autozone has starter checks just to make sure.
Old Aug 5, 2008 | 10:51 PM
Delvin's Avatar
Ignition switch is another possibility going by what was said here.
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
