Need help with pioneer install
Old Aug 7, 2008 | 01:57 PM
G4nismo's Avatar
mods, i know this is kinda the wrong section to post this but the audio/electronics hardly bite and i'm anxious to hurry up and install this. will delete thread once answer is found. hope you don't mind.
bought a pioneer DEH-P6000UB and have 1 question.
on the wiring harness, theres a blue/white wire that says:
connect to system control terminal of the power amp or auto-antenna relay control terminal (max 300mA 12 V DC).
where can i find this? can anyone w/ a FSM point it out?
Old Aug 7, 2008 | 02:01 PM
OK.Eric's Avatar
Sorry, I don't know the answer to your question, but you can download the FSM for free in PDF form.
Here's where I got mine:
http://www.phatg20.net/component/opt...tory/Itemid,2/
I think you have to sign up on this site to be able to download, and for some reason I was having problems getting the download to start, but play around with it and you should be able to get it eventually.
Old Aug 7, 2008 | 02:05 PM
G4nismo's Avatar
thanks, but i already have the FSM. just wondering if others that have it could point it out or just tell me which pin# or wire, etc...
Old Aug 7, 2008 | 02:15 PM
vilmaxima's Avatar
That wire is used to hook it up to your amp remote wire(usually blue and skinny), if you are not running subs and amp, it is not used.
Old Aug 7, 2008 | 02:33 PM
WhiteA32's Avatar
Yeah man unless you have an amp that wire does nothing for you.
If you do have an amp, you connect it to it, and it basically tells your amp to turn on and off with the HU. So don't worry about it
Old Aug 7, 2008 | 02:40 PM
Exactly! One less wire to worry about.
G4nismo's Avatar
ahhhh ok. SWEEEETT!!!! thanks you guys!
i will soon be completely done w/ my interior. expect some pics very soon
Old Aug 7, 2008 | 02:43 PM
alset2's Avatar
what about the power antenna??
according to the fsm it is a black wire with a red stripe
Old Aug 7, 2008 | 02:45 PM
vilmaxima's Avatar
One thing I may suggest is to put a switch on that wire if you are running it, that way you could turn the subs on/off with the switch of a button.
Old Aug 7, 2008 | 02:52 PM
vilmaxima's Avatar
It is the fat black wire(bottom right IIRC when looking at it head on) that has a 90 degree bend(factory) and I guess looks like a large headphone jack type thing, this works our power antenna.
Old Aug 7, 2008 | 02:58 PM
alset2's Avatar
so the switch wire is built into the actual antenna plug...cool.
learn something new everyday, thanks
Old Aug 7, 2008 | 03:05 PM
WhiteA32's Avatar
vilmaxima
My 4 year old headunit allows me to turn on and off the subs...if anything I would install a switch that allows you to turn the HU on after the car is off...
Old Aug 7, 2008 | 03:11 PM
vilmaxima's Avatar
vilmaxima
Thats a nice feature, with my HU I cannot turn the subs on/off or even the amp, which is why I did mine this way with the switch at the amp remote. Turn that on/off, so will your amp/subs. With your setup does it turn the subs off only or the amp also? You can turn the HU on by simply switching your key to ACC. Even when the car is off, I can turn my amp/subs on/off with the switch(in ACC). Lets say Im at the drive-in watching two movies, if I want subs, I turn the switch ON, now I have bass. Thats gonna leave you stranded though(with my setup anyways), which is why I do it like this. That and sometimes I wanna drive without subs
Old Aug 7, 2008 | 03:30 PM
WhiteA32's Avatar
I can only turn my sub off, well maybe I should rephrase that. I can have it so no sound comes through the sub. The amp doesn't turn off as far as I know...
I have my front components amped as well they are on when I turn the sub off
Old Aug 7, 2008 | 03:45 PM
vilmaxima's Avatar
Ok, the way I do it, when you turn the car off, and its just ACC with stereo, I can still turn my amp/subs on with the hit of that button with the HU beeing ON the whole time. When you turn amp/subs ON it will drain the battery very quick. Now, when you turn the switch OFF you are back to factory stereo. I dont know if that makes much sense to you, but like this you cut off all power to your aftermarket stuff(except HU). I think what you are referring to as turning down your subs, is an option on your HU to controll it(got it too), but that way power is still running to everything I have done probably over 20 installs, almost 100% of those people came back wanting the switch put on.
Old Aug 7, 2008 | 03:47 PM
G4nismo's Avatar
ok, everything is working fine except i'm getting no reception from the radio.
i'm a complete audio newb so be easy. also, the power antenna doesn't work b/c the cord is just sitting there.
what do i do? do i need some kinda cord for the antenna jack behind the HU?
i don't have subs, just running on the stock speakers.
Old Aug 7, 2008 | 03:49 PM
arrocha87's Avatar
yea u need an adapter for the nissan antenna to fit. its called the nissan diversity antenna adapter. it costs like 5.99 at walmart. because we have an antenna with dual plugs instead of the regular plug in most aftermarket HUs
Old Aug 7, 2008 | 03:50 PM
adriena's Avatar
You might need an adapter so that the radio cord can fit. I had to get an adapter for my aftermarket sterio
Old Aug 7, 2008 | 03:52 PM
vilmaxima's Avatar
Didnt mean it in any hard feelings type o way, just trying to explain and make things clear and more understandable. And yeah, +1^ for the antenna adapter, should be plug n play to your factory
Old Aug 7, 2008 | 03:55 PM
G4nismo's Avatar
thanks man! you sure walmart carries that? im about to head on over there...
Old Aug 7, 2008 | 03:58 PM
arrocha87's Avatar
well mine does but im in dallas, so who knows. they carry it over here because i just did my D2 install a lil while ago if you remember me asking Qs on here and the audio forum. It might be a universal one with like 3 diff inputs on one end but just use the one we need and your good.
Old Aug 7, 2008 | 04:07 PM
G4nismo's Avatar
oh ok haha. well i'll check walmart and if they don't have it, hopefully circuit city across the street has it.
i'll post pics of everything installed tonight
Old Aug 7, 2008 | 04:14 PM
vilmaxima's Avatar
My bad for forgetting about the antenna adapter
Old Aug 7, 2008 | 07:39 PM
arrocha87's Avatar
so was it at walmart? lol i see from your other thread you go it put together.
Old Aug 7, 2008 | 07:44 PM
G4nismo's Avatar
nah walmart didn't have it. luckily circuit city had some but was $17
Old Aug 7, 2008 | 08:35 PM
arrocha87's Avatar
damn rip off! lol but its probably better quality than walmarts schoche or however u spell it.
Old Aug 8, 2008 | 12:31 PM
matrix11229's Avatar
I guess I paid $14 at best buy.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
