when to replace springs?
Old Aug 8, 2008 | 12:00 PM
vettefever5's Avatar
i have a 97 with ~155k miles on it and the shocks/struts from what i can tell are pretty shot. they creek when i take corners, they "thunk" when i hit bumps, and the rear of the car takes very minimal effort to bounce it like it's on hydraulics.
my question is, how do i know when it's time to replace the springs? when i did a lowering job on my old 300zx i did the shocks/springs at the same time, but i've never had to replace springs on any of my cars because of normal wear and tear.
i don't want to put too much money into my car... it's relatively stock, it's 12 years old and it's starting to show its age underneath. i'm debating about how much longer to keep the car, but i know i will at least have to fix the suspension before i either keep it or sell it.
i'll do the springs if i need to but i'd rather not. any thoughts?
Old Aug 8, 2008 | 12:04 PM
mtrai760's Avatar
'Trynna' is not a word
Springs should last the life of the car. Struts only last about 60k miles on any vehicle. You probably have several bushings that need to be replaced as well.
Old Aug 8, 2008 | 12:26 PM
Crooper_Hedder's Avatar
My car's got 196k on what I believe to be the original struts and I don't have any obvious suspension problems.
Old Aug 8, 2008 | 01:11 PM
rp0029's Avatar
Push down hard on one corner of the car. If the car bounces more than once, it needs new springs. I've only seen this on like 15 year old cars. They're pretty sturdy.
Old Aug 8, 2008 | 01:29 PM
mtrai760's Avatar
Originally Posted by rp0029
Push down hard on one corner of the car. If the car bounces more than once, it needs new struts. I've only seen this on like 15 year old cars. They're pretty sturdy.
Fixed.
Springs are not what your testing when you do that.
Old Aug 8, 2008 | 03:38 PM
internetautomar's Avatar
mod or sell?
yes you do have problems you just aren't realizing it.
Put on new struts and your braking distance will decrease by at least 10%.
Old Aug 8, 2008 | 04:17 PM
99grnmaxgxe's Avatar
Replace them with lowering springs.
Old Aug 8, 2008 | 04:38 PM
B_Eaze's Avatar
yea bud, you'll def see major handling braking improvement with new struts. internetautomart knows what hes talkin bout
Old Aug 9, 2008 | 12:40 PM
vilmaxima's Avatar
you probably need new struts, but probably not springs they probably make noise because of your spring isolators, strut bearings or strut mount. Havent heard of stock springs going out on our cars.
Old Aug 10, 2008 | 04:43 PM
MLK's Avatar
MLK
Springs are not components that wear out unless they've been seriously abused. Struts, shocks, and anything rubber are the parts that will need to be replaced as the car ages. If the car continues to bounce after you load/unload the suspension, you're in need of shocks/struts. RP0029 is misinformed.
Old Aug 10, 2008 | 06:05 PM
ptatohed's Avatar
Licensed to Spell
"when to replace springs?"
As soon as you buy a stock 4th gen.
Old Aug 10, 2008 | 06:17 PM
curiosul's Avatar
the "thunk" is not from struts or springs, it's from ball joints and/or bushings
new struts improve braking in general but more so on bad roads (potholes etc.)
Old Aug 13, 2008 | 09:25 AM
Okay that makes sense. Mine doesn't bounce when you push on it.
And yes if I replace my struts I'll get the Progress/Illumina setup that I've been dreaming about for years. Might as well do it right if I'm gonna have it all apart anyway.
Old Aug 13, 2008 | 09:13 PM
CMax03's Avatar
When you get tired of all that gapidus!!!
Old Aug 14, 2008 | 12:26 PM
Krypto's Avatar
Agreed.
Old Aug 15, 2008 | 10:14 AM
deezo's Avatar
DOH!!!! Back to the drawing board dude.
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
schmellyfart
Sep 25, 2015 04:47 PM
95Maxi
35
Sep 2, 2015 10:37 AM
tnewbs
Aug 28, 2015 10:15 AM
