Starting issues
Old Aug 11, 2008 | 11:37 AM
Ahmad_1290's Avatar
Starting issues
I've gotta 97 Maxima, and it starts weird, When its on acc. and i try to start it it wont even click. But when its on off, I've gotta turn it real fast for it to start.
any ideas?
Old Aug 11, 2008 | 01:19 PM
DBear's Avatar
Sounds like an ignition switch issue. Take the covers off to expose the switch, and turn the switch itself using the key or a screwdriver. If it starts every time, you probably have a little slop between the flange on the key cylinder and the slot in the ignition switch. I fixed that by putting a little piece of electrical tape in the slot on the switch, so the flange fits in more tightly.
If it doesn't start any better by turning the switch itself, the switch may be bad. You'll need to start testing by checking for voltage at the contacts on the switch. I don't remember which terminals are which. You should be able to tell from the FSM, or do a search--there's been a lot about ignition switches lately.
Old Aug 11, 2008 | 04:23 PM
vilmaxima's Avatar
yeah ^+1. Most likely your ignition switch, probably starting to go.
Old Aug 12, 2008 | 09:14 AM
Ahmad_1290's Avatar
thanks DBear, it worked.. starts up every time
Old Aug 12, 2008 | 12:15 PM
Bugsnt's Avatar
Interesting... good to know.
Thanks.
Old Aug 12, 2008 | 01:08 PM
DBear's Avatar
Yeah, I think a lot of us have replaced ignition switches unnecessarily. I replaced one and it didn't fix the problem. I finally thought to try the tape, and it's been fine since the beginning of the year.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
