Doors locking automatically
Old Aug 13, 2008 | 04:41 PM
venturous's Avatar
My 96 has been doing it for awhile and my 95 just started locking without being touched. Sometimes they will lock just driving and sometimes when I close the door. It will also lock with the key in the ignition, which it will not normally do if you are getting out of the car without the key.
I figured there must be a "best place" to start before I start tearing into everything.
I did a search but did not come up with anything that matched my problem.
All help is appreciated.
Randy
Old Aug 13, 2008 | 05:07 PM
mtnbikeair's Avatar
I have the same problem, so I am interested in this too. Mine will lock every door but the passenger front door.
Old Aug 13, 2008 | 05:15 PM
venturous's Avatar
Hey Mtn, that small block Chevy looks just like the one in my El Camino, which also spent about 100K miles in a 72 240Z Datsun before I pulled and took it 30 over and installed another L-79 cam in it.
Old Aug 13, 2008 | 05:39 PM
fat_kid's Avatar
mine does that too, i hate it. i wonder what it could be
Old Aug 13, 2008 | 07:07 PM
papo020's Avatar
Mine does that too but it locks them all except the drivers door......?
Old Aug 14, 2008 | 05:23 AM
hornepirate's Avatar
the ghost of Nissan maybe ?
Old Aug 14, 2008 | 06:35 AM
sonicrunch's Avatar
Yep, I've had that happen once while refueling the car. Luckily the front passenger door lock did not lock.
Old Aug 14, 2008 | 06:45 AM
I've got a '96 too and that only happened once. I don't know what could be the source of that. I hope it isn't the ghost of Nissan.
Old Aug 14, 2008 | 07:46 AM
SVI30's Avatar
Find the body control module. Unplug and replug all the connectors on the box. Each door has a control module too. At age of our cars, it is likely a connector failure.
Old Aug 14, 2008 | 07:48 AM
fat_kid's Avatar
i guess that could explain the randomness of this problem, where are the modules? pics?
Old Aug 14, 2008 | 09:23 AM
ThurzNite's Avatar
Not sure about you guys, but on my 97 gxe, when I manually lock the front doors from inside, it'll lock all the doors. There's some switch in there. I once had a passenger leave the lock 1/2 way, and shut the door, which locked all the doors. So I'm thinking, the internal switch somehow got loose from the external (door panel side) lock. I'll check the FSM to see what's going on there. (I don't have the problem, but just sharing knowledge).
Dr J
Old Aug 14, 2008 | 09:37 AM
ThurzNite's Avatar
This should be stickied:
Power Door Lock diagnosis procedure
Pre-diagnosis setup:
Ignition switch: off
dome light: on (this's the map light for front passengers)
rear window defogger: off
doors: closed
interior lamp: center "O" position
1) Turn ignition switch "ON"
2) Return ignition switch to "OFF" and press rear window defogger switch more than 10 times during 10 seconds
3) Self diagnostic results indicator lamps should turn on
4) Rear window defogger switch stays OFF
5) Turn ignition switch "ON" within 5 seconds after the indicator lamp turns on
6) Indicator lamp turns off
...after a second...
7) Mode 3 diagnosis is performed
8) Turn ignition switch "OFF"
9) Diagnosis end
*make sure all lights are out.
Description:
The malfunction code is indicated by the number of flashes from the front map light and step lamps. Count the number of short flashes.
Legend:
Code 1: Driver door lock actuator/unlock sensor
Code 2: Passenger door lock actuator/unlock sensor
Code 3: Rear RH door lock actuator/unlock sensor
Code 4: Rear LH door lock actuator/unlock sensor
Code 5: No malfunction in the above items
What to do if you get Code 1-4? Check door unlock sensor, and door lock actuator.
Dr J
Old Aug 14, 2008 | 10:52 AM
f550maranello2's Avatar
ok the problem seems to be that he door doesn't unlock all the way my car does it too.. it looks like the problem here is the actuator OR the linkage is being restricted somewhere.. i noticed that if the door lock only opens like 50 percent then when u close the door it locks on its own... OR when u unlock it locks on it it own...
so i see it as 2 possible scenarios.. actuator failing or the linkage is getting caught onto something
Old Aug 14, 2008 | 11:16 AM
vilmaxima's Avatar
If you guys havent tried it yet, unplug your BCM connectors and plug them back in. The BCM is in the trunk on the antenna side. Just peel back the lining and its a black box. If it doesnt work try it again but also disconnect the battery.
Old Aug 14, 2008 | 11:58 AM
Nopike's Avatar
I believe the BCM is inside the car behind the stereo headunit the box in the trunk is the remote control module. Would not hurt to disconnect and hopefully reset the both of them.
Old Aug 15, 2008 | 12:17 AM
ThurzNite's Avatar
Did you go through the procedure I listed? If so, I'll post the next steps. Please let me know what code you got, so I can put up the proper steps.
Dr J
Old Aug 20, 2008 | 09:06 AM
GreenMtnMaxima's Avatar
Dr J
I share the same problem as venturous, fat_kid, et al. I did Dr. J's (or is it thurznite?) diagnosis procedure, but my map light didn't blink at all in diagnosis mode.
What does that mean and what should I try next? The BCM method mentioned by the others here?
Has anybody out there successfully solved this problem?
Many thanks.
Old Aug 20, 2008 | 09:16 AM
tyler5619's Avatar
not to say Dr J is wrong, because he obviously knows his shxt, but i would have started by reprogramming the keyless remote, then maybe pulling fuses and reinserting them
Old Aug 20, 2008 | 09:53 AM
I'll consider trying that, but it doesn't seem logical to me. I've never had any problems with the keyless remote - it always works fine. The locks respond correctly when I use the remote. It's when I'm not using the keyless remote that my locks act up - when driving, closing doors, etc.
Is my hunch wrong? Why do you recommend reprogramming the keyless remote?
Old Aug 20, 2008 | 10:04 AM
tyler5619's Avatar
that was just my hunch. maybe there's something getting confused and your receiver thinks you're pressing a button. that doesn't explain why one door is not locking. hmm....
disregard
Old Aug 20, 2008 | 10:21 AM
tbizzle's Avatar
I have a 97 and if the lock gets stuck 1/2 way, it will lock all the doors. If you try to unlock it 1 second later it locks again.
Old Aug 20, 2008 | 03:45 PM
thedwyer00's Avatar
I have the same problem with mine I just have been doing too many other things to my max to worry about that. I'll look into it and see what I can find.
Old Aug 21, 2008 | 12:54 AM
rocksteadyracer's Avatar
Sounds like a short somewhere. My 93 240sx used to send the seat belts forward and back by themselves (auto belts). I never figured it out but I'll bet your problem is in the dash harness behind the steering wheel.
Old Aug 21, 2008 | 11:21 AM
fat_kid's Avatar
doors: closed
9) Diagnosis end
Description:
Legend:
Dr J
I did this and got a code 2, what should i do now
Old Aug 21, 2008 | 05:32 PM
ThurzNite's Avatar
I just typed what's in the FSM... it says by starting out with this procedure. Later on, it'll say reprogram.
I'm helping a member swap his knock sensor tonight... if I'm not too tired, I'll post the follow up to code #2.
Dr J <-- Dr J, like the hall of fame basketball player, 5 highest scorer of all time. I like playing basketball, and was told I play like him.
Old Aug 25, 2008 | 11:25 AM
CDA's Avatar
CDA
I have a Maxima (actually it is my wife's) with this same issue and have been trying for a long time to figure it out with no luck. I am excited that I finally did a search and found some information. Thanks for the info.
I did the procedure and got a longer signal followed by a 2 shorter pulse flashes. I guess this is a Code 2. What should be done next? How do I get to and check the door unlock sensor and actuator? I am not very familar with electronics diagnostics, but know my way around the car okay.
Again,
Thanks for any help.
Old Sep 23, 2008 | 05:18 PM
96SEmaxB's Avatar
My 96 locks too, sometimes my wife hits the door with her knee (passenger side) and they'll all lock, but most of the time i'll be driving by myself and they'll all just lock, it's really weird... Sometimes i'll even fight with it going back and forth unlocking and locking by it's self...
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
