Need help finding the TAM screw for RPM switch
Old Aug 16, 2008 | 02:51 PM
nanomax96's Avatar
Hi Guys as some of you all know I just finished installing MY 00 VI and the car starts with no problems thans to some ORG. Members for their help and advice.
Anyways I'm working on installing the RPM switch and I can't find the TAM screw. I though it was located in the back of the Display Bezel I took it off and I saw a screw labeled TM not TAM is this the right one?
Thanks for all your help in advance.
Old Aug 16, 2008 | 03:02 PM
CRiME's Avatar
oem ftw!
If memory serves me correctly, 98+ do not have the TAM screw. If your car is a 98-99, You may have to tap into the ECU wire - it's the white wire with the green stripe, pin #5.
Illustration here, credit to g4nismo:
I initially attempted the ECU method but decided on the TAM screw because it is such a tight cluster of wires. The RPM signal wire seemed to be buried, of course, deep inside of the bundle
Old Aug 16, 2008 | 10:50 PM
pmohr's Avatar
No more Maximas...
FWIW, from a '95:
You can also pull the tach signal from connector M50/F105, it's a white connector on the engine control harness, plugs up in the ECU area, next to the BCM. I believe you can get to it just by removing the driver side ECU access cover, undoubtedly a lot easier by removing the radio and BCM, though.
Looking at the back of the engine control harness side of the connector, clip up, it's the 3rd pin from the left, top row (W/G, it comes straight from the ECU to this connector).
Pics:
Old Aug 17, 2008 | 06:14 AM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by pmohr
FWIW, from a '95:
Pics:
Excellent post!!
Old Aug 17, 2008 | 06:42 AM
pmohr's Avatar
No more Maximas...
Originally Posted by Flava_24/7
Excellent post!!
Yea, I think I've filled my quota for the week.
Old Aug 17, 2008 | 04:19 PM
nanomax96's Avatar
Thanks to everyone for your help. Got everything working and man I can definetly feel the pull all the way to redline. I can't wait to go to the track and run it.
Old Aug 17, 2008 | 07:19 PM
RA030726's Avatar
I'm nutty for Nissans
Yea my 98 does not have the TAM screw. I had to get it at the ECU.
mvm062
Nov 30, 2020 09:00 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
dcardello
Sep 3, 2015 11:44 PM
