Climate control only blows thru front vents
Aug 28, 2008 | 07:11 PM
Has anyone had this problem? It's a manual Climate Control. It doesn't matter which button I push, the air will only blow thru the front vents. AC works as expected, it's just the air movement.
Just curious if this is a common thing with the Climate Control or it's deeper into the flaps. The problem is actually on a 2000 maxima. The units look to operate the same between the 4th and 5th gens. I posted in the 5th Gen's but haven't had any responses so branching out for info.
Aug 28, 2008 | 07:28 PM
uhm which vents do u mean? maximas only have vents in the front... we dont have back seat vents or anything... well not 4th gens anyways...
Aug 28, 2008 | 08:31 PM
look under the drivers side floor board and the a/c has somewhat of an arm that controls the flap that switches from floor to front you might want to check that it might of came loose like mine did all you have to do is hook it back to the flap.
Aug 29, 2008 | 06:43 PM
Quote: look under the drivers side floor board and the a/c has somewhat of an arm that controls the flap that switches from floor to front you might want to check that it might of came loose like mine did all you have to do is hook it back to the flap.
Thanks for the advice. I'll take a look...
Aug 29, 2008 | 06:45 PM
Quote: uhm which vents do u mean? maximas only have vents in the front... we dont have back seat vents or anything... well not 4th gens anyways...
Scoobz - I was referring to not blowing thru the defrost vents at the bottom of windshield or down by your feet.
