help idler pulley belt fell off
Old Aug 30, 2008 | 11:38 AM
hotimportnight9's Avatar
i was looking at the belts they look fine check the idler pulley was tight so was the belts all of the sudden i remote started my car like 5 min running the idler pulley belt just fell off its still intact n the power steering belt is twisted i check all the pulleys to make sure their not loose seems fine no pulley came off, ima replace the all the belts but is there something else i should check?
Old Aug 30, 2008 | 03:13 PM
pmohr's Avatar
No more Maximas...
By 'idler pulley belt' you mean the AC/alt belt? You say it's 'still intact' but does it show any signs of glazing, or being burnt up?
It shouldn't just throw a belt, but check to make sure the compressor and tensioner pulleys aren't seized up.
Old Aug 30, 2008 | 04:12 PM
arrocha87's Avatar
or maybe you tightend the pulley but not the pulley bolt or vice versa.
Old Aug 30, 2008 | 04:30 PM
pmohr's Avatar
No more Maximas...
If you tighten the locknut in the center of the tensioner pulley, it isn't going anywhere. If you don't, however, it's prone to fall off.
But he's saying his belt came off...I think.
Old Aug 30, 2008 | 07:02 PM
yes the ac/alt belt everything look good the belt is 100% intact no burnt mark nothing what so ever but as i was try to put the new power steering i found out that it did not want to sit in right when i turn the crankshaft pulley by hand it turns the belt side way so i had a friend of mines turn the key to see the crankshaft puley was ok and its bent causing the belt to pop out so i have to replace the crankshaft pulley, should i get a oem one or put an aftermarket ud pulley like the unorthodox one?
Old Aug 30, 2008 | 07:04 PM
pmohr's Avatar
No more Maximas...
I'm guessing it seperated at the rubber section? Might as well just go stock, UDPs are nigh worthless.
Old Aug 30, 2008 | 11:23 PM
yeah thats what my mechanic said he mention something about a rubber part in between messing up should i change anything else while im down there?
James92SE
142
Jan 2, 2024 09:23 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
