What king of Spark Plugs does your 4th gen have?
Sep 2, 2008 | 11:43 PM
i just installed bosch double platinum, working great so far.(3 runs) i also hear that some bosch plugs can make engine a little iffy? NGK's kinda expensive i had those on.
Sep 3, 2008 | 12:11 AM
OEM spark plugs FTW. I don't have a supercharger or a turbo, so the stock ones will do fine.
Sep 3, 2008 | 12:34 AM
ngk iridium ix, the name alone makes sound nice
Sep 3, 2008 | 12:57 AM
only NGK for the VQ!!! I have the stock platinums and will never go to another brand other than NGK
Sep 3, 2008 | 01:00 AM
ngk iridium...even though expensive
Sep 3, 2008 | 05:40 AM
definately gotta go with the ngk iridium ix. really hot spark
Sep 3, 2008 | 06:27 AM
NGK platinums.
NGK spark plugs are the ONLY kind of plugs you are supposed to be using in a maxima.
If you dont want to spend the money for platinums or iridiums, get coppers - but still get NGK coppers.
Sep 3, 2008 | 07:26 AM
for $2 per spark plug the NGK copper is a great deal. Every1 here will tell you use NGK copper for cheap plugs but change every 30k or double laser cut platinum's for $9-10 but they last 60k miles. i had the double cut platinum's and couldn't tell the difference. i just use the copper ones, less money and almost always in stock.
never used ngk iridium so cant say nothing about them
Sep 3, 2008 | 08:26 AM
If you would have searched, you would have found out that our cars come with ngk platinum. Why would you want to use anything other than that??
Sep 3, 2008 | 08:51 AM
From years of expirience with many types of vehicles I'd say don't switch from the OEM brand. The cross charts aren't very good because each plug manufacturer makes their plugs differently. I tried Champions in a Honda bike. They were too cold, fouled badly. Tried NGK's in stead of Bosch in an air cooled VW, same problem. I let someone put Bosch plugs instead of Autolite in a Ford Aeorostar. Destroyed the motor. They ran too hot, warped the heads.
Sep 3, 2008 | 09:05 AM
NGK platinum
Sep 3, 2008 | 09:58 AM
Quote: From years of expirience with many types of vehicles I'd say don't switch from the OEM brand. The cross charts aren't very good because each plug manufacturer makes their plugs differently. I tried Champions in a Honda bike. They were too cold, fouled badly. Tried NGK's in stead of Bosch in an air cooled VW, same problem. I let someone put Bosch plugs instead of Autolite in a Ford Aeorostar. Destroyed the motor. They ran too hot, warped the heads.
Exactly! I have noticed this from reading the forums of every car I have owned. Stick with the equivalent it was designed to run on. People on my VW forum when I owned my Golf talked about nasty problems on anything other than Bosch, same when I owned my Taurus, nothing but autolite, and same with the Maxima, nothing but NGK.
Same here, I am using the NGK coppers with the little v-slit in them because they were the cheapest thing and the only thing in stock. It is much cheaper, and plus I would rather change them at 30K or before and check things out anyway.
Sep 3, 2008 | 11:08 AM
NGK coppers
Sep 3, 2008 | 11:11 AM
Platinum 4's and I lol'd at the thread title.
Sep 3, 2008 | 11:16 AM
http://forums.maxima.org/4th-generat...st-maxima.html
and from the Stickies
http://forums.maxima.org/4669104-post51.html
and
http://forums.maxima.org/4669891-post52.html
Sep 3, 2008 | 02:55 PM
i had the iridiums ix but switched them out i like the new ones and working fine ive heard to only use ngks but some people used bosch and worked fine. i think im gonna go ngks copper next time. hey btw how do you gap spark plugs..yes im a noob
Sep 3, 2008 | 03:15 PM
Putting Bosch spark plugs in a Maxima =
Sep 3, 2008 | 03:58 PM
i've got Ngk copper plugs... i noticed a lil pick up from my stock plugs
Sep 3, 2008 | 04:12 PM
NGK Plats FTW! $2.69 at Autozone.
Sep 3, 2008 | 04:59 PM
NGK Iridiums only for me
Sep 3, 2008 | 05:34 PM
Quote: NGK Plats FTW! $2.69 at Autozone.
You must be referring to the NGK G series plug, not the Laser Platinum OEM style plug. Might as well get the coppers IMO if you're not getting the real deal at $8.25 each.
Sep 3, 2008 | 06:00 PM
Check the Sig lol NGK FTMFW
Sep 3, 2008 | 06:17 PM
NGK in a nissan
Denso in Toyota
AC/Delco in GM
Motorcraft in Ford
Bosch in old german cars (new ones are NGK)
I actually have no clue what plugs are in my car right now, as I did not change them yet. when I do they will be NGKs.
Sep 3, 2008 | 06:49 PM
Quote: NGK in a nissan
Denso in Toyota
AC/Delco in GM
Motorcraft in Ford
There's is a few exceptions to this list but the Maxima is not one of them.
One that comes to mind is LT1/LSx cars run much better on NGK TR55 plugs then OEM.
Sep 3, 2008 | 07:04 PM
Quote: Exactly! I have noticed this from reading the forums of every car I have owned. Stick with the equivalent it was designed to run on. People on my VW forum when I owned my Golf talked about nasty problems on anything other than Bosch, same when I owned my Taurus, nothing but autolite, and same with the Maxima, nothing but NGK.
Im using NGK coppers as well, when I purchased these from Nissan all 6 for 15$ the guy told me "why am I using the Altima spark plugs" I told him because the guys on Maxima.org said so he then told me my car would run like crap with them . Its been about 3,000 miles on them since and havent noticed any difference from the platinums at all. I'll stick with my 15$ plugs
Sep 3, 2008 | 07:26 PM
Quote: There's is a few exceptions to this list but the Maxima is not one of them.
only when modded, stock they work just fine in my experience
Sep 3, 2008 | 07:33 PM
Idk whats in my car right now. But with my minor mods that i had i think imma go with the NGK copper.
Sep 3, 2008 | 10:11 PM
yea i always put in spark plugs that were in the maxima originally.
Sep 4, 2008 | 10:37 AM
i use ngk iridium plugs. i know it's been said but your only suppose to use ngk's on our cars!
Sep 4, 2008 | 12:47 PM
OEM all the way
Sep 4, 2008 | 03:29 PM
NGK platinums here
Sep 4, 2008 | 03:59 PM
ngk coppers ftmfw
bosch sucks and anything besides ngk in a maxima sucks *****
Sep 4, 2008 | 09:45 PM
NGK platinum
Sep 4, 2008 | 10:44 PM
NGK Platinum...
Sep 7, 2008 | 07:48 AM
NGK IRIDIUM IX.
Sep 7, 2008 | 10:06 AM
putting german plugs in jap cars is always bad. from experience I'd say NGk is the best for jap cars but denso is almost just as good. OEM is always best but if that is 2 expensive alteast stay in the same country. Don't buy American or german parts for jap cars and vise versa.
Sep 7, 2008 | 05:20 PM
Quote: NGK platinum
+1
Sep 11, 2008 | 03:36 AM
NGK Iridium IX.. Only the best..
Sep 11, 2008 | 06:04 AM
NGK platinums are the king I use.
Sep 11, 2008 | 07:04 AM
NGK when i bought the car it had osch platinum but i changed to ngk and can actually feelthe difference
