Stalling problem
Old Sep 3, 2008 | 04:03 PM
maxima-junky's Avatar
Stalling problem
My 95 auto sometimes shuts off when I driving it. It stops the dash lights illuminate then it starts back up like nothing happened when I turn the key. I think this is a dangerous thing when I cruising on the highway. Anyway does this sound like a maf problem or an 02 sensor. I'm making a scrap book of newbie comments so guys have at it.
Old Sep 3, 2008 | 08:28 PM
pmohr's Avatar
No more Maximas...
I assume you've checked for codes?
Old Sep 3, 2008 | 11:00 PM
I was told that if the check engine light isn't on I wouldn't get any codes. I don't know how true that is.
Old Sep 3, 2008 | 11:21 PM
pmohr's Avatar
No more Maximas...
The only code that should be present with the CEL off is a KS code, really.
Any specific situations, climate conditions, other discernable patterns when this occurs?
Old Sep 3, 2008 | 11:36 PM
khantalha+'s Avatar
well maf is one thing check both ur battery terminals first and tighten em up...my car was doin it to me when i had that problem....tightened those babies up and never had no problems
khantalha+'s Avatar
like pmohr said; the only code ull have without the ligh is the KS code
Old Sep 4, 2008 | 12:20 AM
Rob20's Avatar
mine did the same thing and shifted a bit weird. i found it to be the Mass airflow,MAF the knock sensor wont turn off your car.. so i hear. anyways check where the conection is on your MAF and make sure that the screws are on all the way. i took my screws off and pushed the 3 things i saw sticking out a little more in and fixed my problem. no more turning off car. maybe it could work for you.
dont know if all my info is right but worth a try
Old Sep 5, 2008 | 05:42 PM
GAMaxima95's Avatar
I had the exact same problem. extremely scary. especially speeding through curvy North Georgia mountain roads. Mine would cut out almost exclusively when I applied the brakes. Very confusing and frustrating. Finally I discovered that I had corrosion built up on the inside of my battery terminals (no build up at all on the outside)scraped it all off and it was all good for 3 or 4 months. The problem returned so I replaced the battery and terminals. So far, So good.
Old Sep 11, 2008 | 01:32 PM
Anyone ever heard of cam position sensors? Do we have the in our cars?
Old Sep 11, 2008 | 04:08 PM
pmohr's Avatar
No more Maximas...
Yes, and yes.
Old Sep 12, 2008 | 12:42 AM
represent24's Avatar
try cleaning your MAF with CRC Mass AirFlow Sensor! that sounds like your problem to me!
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
