Lowering Car by Heating Stock Springs?
UPDATED
Ok Thank, you everyone for all your replies, for now I will leave the stocks alone, I found another brand here called Dropzone's? are these any good? its a 2" drop Front/Rear, What's the Maximum drop I should do on brand new KYB Gr-2's? I would like at least 1.5" front and rear but 2" if possible with out damaging my car, as I really hate the look of wheel gap... or I could just leave it alone, and get a RSB for better handling at the height it's at...
These are all my choices that I've found,
Eibach Pro Kit, H&R Springs, or Tein S. Tech
http://www.modacar.com/products/Nissan/Maxima/Springs/
Sprint Springs
http://www.racinglab.com/nissan-spri...rings-009.html
Dropzones? (Anybody ever heard of these?)
http://www.slickcar.com/productdetai...ProductID=1670
Sprint Springs
1- GR-2s shouldn't be used with anything but a mild drop. They will blow eventually.
2- DO NOT HEAT YOUR STOCK SPRINGS, especially for a 2" drop. 1.5"F and 1.5" rear can be had with Eibach springs, 1.7-2ish and 1.5ish rear can be had with Progress springs. You can get either used on the cheap.
The springs already go through a very specific heating and cooling cycle in order to get the elasticity that is required for them not to just snap.
I can almost guarantee that your springs will become very very brittle and will snap when put under any load.
You are better off buying cheep ebay springs then doing this. But IMO do it right and spend the money for legit springs or dont do it at all, you will save yourself all kinds of headaches
Your Gr2's cant handle anything more than like .5'' of drop. They will be toast in 6 months or less. If you want to drop it that much you need the AGX's
I had a friend with Dropzone coils and he seemed like them. The ride was a little harsh but what do you expect from stiffer springs. He was also running gr2's which didnt last long.
I am a Mechanical engineering student and am taking all my material science classes right now. I may just be a nerd but it is kind of cool to me how you can change the properties of metals like this. It would be nearly impossible to preform your own forging and tempering operation especially when all you have is a torch...
I thought that the GR-2s are quality springs... I dont understand why they wouldn't last with a 1.5" drop with the eibachs? Are they really that poor quality of a spring? KYB is known for their suspension, I cant think that it would be that cheap, and not take a little drop? There performance struts.
Well the basic make up of a strut is a chamber with oil and seals in it, it can only take a certain amount of pressure before the seals blow. The lower the ride hide of the spring, the more weight the strut is holding up, hit enough good bumps, pressure builds in the strut and the seals blow. GR2s are really just a stock replacement. Just save your money for a quality drop. If you nickel and dime you will spend more money cause you just end up doing stuff twice.
GR-2's are AGX set on 2. They can handle eibach springs no problem. I ran AGX on 2 with a few different springs, over a few year period. No issues other than lack of travel.
Dropzones are cheap, one member had them break into pieces. With stock sized struts dont go lower than 1.5". Even then you have limited travel.
Wrong x1000
The GR2 may be the the AGX on #2 setting in terms of stiffness but the AGX is designed and built tougher to withstand the extra pressure associated with a bigger drop.
The real problem is that each spring is going to yield differently and have radically inconsistent spring rate and corner weighting. What the person who's considering this needs to know is that they will end up with at least one wheel that isn't pressed down to the pavement, causing the car to have terrible handling when you need it most. It might be similar to driving around on one tire running 10psi too low, or one wheel with a tire that's smaller than the others.
Dave
Actually, it would alter the yield point of the material. Elasticity is essentially constant through all types of carbon steel at room temperature.
Actually the heat will ruin the temper of the springs which lowers the yield point and makes it less brittle. A tempered spring is hard and has high yield and ultimate strength which makes it susceptible to fatigue, while a torched spring will sag (yield) instead.
Dave
Dave
The moral of the story is spend real money on a real drop.
I'm a little new to this stuff but if my studies serve me well heating and quenching them quickly will make them hard but brittle. heating them and allowing them to cool slowly could cause any number of unpredictable results based on how hot they got and how quickly they cool.
Lakersallday24
06-16-2019 01:35 AM
