need some input
Old Sep 16, 2008 | 06:57 AM
deadmax96's Avatar
need some input
97 max. Just replaced slave cylinder, master cylinder and hardware. Not seeing any leaking from the lines. using dot3/4 fluid. clutch, flywheel has 3000 miles on it. recently changed.
my problem is that the pedal sticks to the floor as if there is air or no fluid in the lines. has this happened to anyone. and if so how extensive is the work. Will this be leaning more towards a trans rebuild or replace everything all over. I double checked my work had a friend help me bleed the lines. After bleeding pedal feels good and she runs fine. but after sitting for a minimal of 3 hours pedal sticks to the floor board and i have to bleed all over again just to it our of gear.
any help is appreciated thanks guys/girls
Old Sep 16, 2008 | 07:14 AM
pmohr's Avatar
No more Maximas...
Well, seems there's still a leak somewhere, air is getting in somehow if you have to continually bleed it. Recheck everything, have someone pump the clutch as you watch all of the junctions.
James92SE
142
Jan 2, 2024 09:23 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
gigabyte
Jan 6, 2017 06:05 PM
gman214
Sep 25, 2015 03:03 PM
catalinvint
Sep 16, 2015 07:48 PM
