car is shutting down
Old Sep 20, 2008 | 06:55 AM
95stillenmax's Avatar
car is shutting down please help
my buddy has a 97se and when it reaches normal operating tempature it shuts down and there is no cell anyone had this happen to them or have any idea what may be causing it?
thanks Brandon
Old Sep 20, 2008 | 07:55 AM
B_Eaze's Avatar
Is the car doing anything else? Does it spudder or just cut out? Make any specific noise?
Old Sep 20, 2008 | 08:22 AM
Snypa's Avatar
More information needed brother.!!
Old Sep 20, 2008 | 09:38 AM
Divewjason's Avatar
Did you check the battery? It probably isn't the problem but it's a start. I've seen batteries cause some weird stuff to happen. The battery will be fine and all of the sudden it's like it has no power. Then after it sits for a while it has a charge again then it just all keeps repeating. One of my friend's Sentra's did something similar to this and it was the battery. It just didn't make any sense.
Old Sep 20, 2008 | 02:19 PM
it sputers cuts out and back fires a little
Old Sep 21, 2008 | 10:26 AM
anyone have any idea what might be causing this it runs fine when its cold then when it gets to normal temp it starts acting crazy
Old Sep 21, 2008 | 10:34 AM
Sherwoodlax33's Avatar
do you have an aftermarket intake? My car is currently doing the same thing, does it like almost stall out when you're in a low gear, but stay at like 300 rpms even when you pump the gas afew times?
Old Sep 21, 2008 | 10:38 AM
djipka's Avatar
mine did something like that and it was the ECT sensor
Old Sep 21, 2008 | 01:32 PM
Snypa's Avatar
Sounds Maf-ish.
Old Sep 21, 2008 | 02:17 PM
B_Eaze's Avatar
MAF first, is it plugged in? Did they filter get moved out the way for some reason and now its dirty?
Old Sep 21, 2008 | 02:34 PM
Feldman's Avatar
+1 for it sounding MAF-ish
Old Sep 21, 2008 | 04:43 PM
maf is pluged in but would it throw a code? because there are no codes
Old Oct 5, 2008 | 09:47 AM
Chitownson's Avatar
Was any work done to the car before this started?
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
