Help!!! Car Dieing!!!
Old Nov 9, 2001 | 04:00 PM
Dahnryman's Avatar
ok,,, I took off the stock air box...the ne behind the filter and replaced it with piece of tubing that goes straight into the TB... then i connected the two hoses that went into the box to a T bracket with a small blitz filter of the small end of the T... ran fine and the intake was extremely loud but when i got to a stop light I noticed the idel was up and down from 1100 to 600 then it just died...it started right back up but i don't know why it died...is the blitz filter not big enough? or is it causing a vacum?
and can somone give me a link to dons ecu troubleshoooting guide?
Old Nov 9, 2001 | 04:04 PM
Dahnryman's Avatar
nevermind the ecu trouble shoooting thing
as the post ****** would say use the search.....i did and i found it...so yes i learned from the post ******
Old Nov 9, 2001 | 04:06 PM
WaarrEagle's Avatar
Is your MAF sensor hooked up somewhere in there??
Old Nov 9, 2001 | 04:08 PM
Dahnryman's Avatar
yes
the MAF is hooked up right behind the JWT as it is supposed to be....im about to check the ecu code now
Old Nov 9, 2001 | 04:13 PM
Dahnryman's Avatar
ecu code
says its maf but its hooked up and working?
Old Nov 9, 2001 | 05:21 PM
Chunger's Avatar
My other car is a Hybrid
Clear the code and run it again...
Did you check for loose connections? vacuum lines especially.
Old Nov 11, 2001 | 01:21 AM
Dahnryman's Avatar
i put the stock air box back on
and the dreaded check engin light went off...and has not come on since...
What is it that the two 5/8 tubes do that go to the original intake housing?...and why would that affect the MAF? beins it is befor the TB?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
