Alternator might be going...
Old Sep 29, 2008 | 09:09 AM
maximase86's Avatar
I love lamp.
...but here's the interesting part. My brake and battery lights come on and they are super bright. The really interesting part is they don't stay on either. Sometimes it goes away and is fine for the rest of the day. Sometimes if I rev the motor, the lights go away...or turn on. Has anyone noticed this erratic behavior? I'm thinking that I might have a bad voltage regulator. Also I noticed whining thru my stereo...but I have ground loops on everything.
Thoughts? Comments?
S
Old Sep 29, 2008 | 10:00 AM
internetautomar's Avatar
mod or sell?
voltage regulator, which is internal to the alternator.
Old Sep 29, 2008 | 11:08 AM
t65k3's Avatar
Still Learning
Maybe you could find someone to rebuild whatever's broken there instead of replacing the whole thing. Save $. I paid to rebuild mine when the alternator caught on fire last time.
Old Sep 29, 2008 | 11:25 AM
Mr.A32ftw's Avatar
Had the same problem and just ingnored it to the light just stayed on and the car just died on me. Best bet is to get a new alternator
Old Sep 29, 2008 | 01:07 PM
B_Eaze's Avatar
i just got this too. i removed the splash guard where the oil filter is and i think the alt got too wet. something in ur alt is giving up
Old Sep 29, 2008 | 01:16 PM
j2b4osan's Avatar
same ish here intermittent br+ba lights=bad alt.
Old Sep 29, 2008 | 08:41 PM
JY05's Avatar
you know what man.. im having that EXACT problem right now.. my audio even cuts off at times.. found out that the alternator is dying.. so best that you change to a new alternator ASAP before your car dies on you and you get stuck in traffic
Old Sep 29, 2008 | 08:49 PM
I'd get that alty changed/rebuilt right away before you're left stranded on the side of the road.
Also, there's a cool gismo you can buy at Walmart that plugs into the cigarette lighter and it tells you the condition of the battery and the alternator. I'm sure you this, but I'll mention it anyway that Autozone, Kragen etc will test it for free.
Old Sep 29, 2008 | 09:46 PM
KRRZ350's Avatar
^^Will tell you volts only though, not amp's, amp meter ftmfw.
Just an fyi, that little royal pita electrical connector on the alternator, make sure it has clean contacts and is fully seated, allthough that tends to cause the battery & brake lights to flicker. The other thing to do after that is to clean the power connection on the alternator, seen those cause problems also.
Old Sep 29, 2008 | 10:08 PM
Sure, but just like Horsepower is a function of torque, Amps is a function of Volts. AmpsxOhms=Volts. The Gismo I described does the job, no??
Old Sep 30, 2008 | 08:43 AM
maximase86's Avatar
I love lamp.
I wouldn't be surprised if the connection is the problem. I've had a mysterious oil leak that I've had a helluva time pinpointing...even Ian had a problem finding it. The alty is covered with oil...so I wouldn't be surprise if it's causing problems with the connection.
Either way, the good news is my wife and I commute into to work together. So we can park the car and worry about it later.
S
TallTom
57
Oct 14, 2025 05:16 PM
