how do i change a ball joint? ( yes serched)
Old Sep 29, 2008 | 10:08 AM
enik23's Avatar
can any one give me a link or someting, and is this a do it yourself job or not really?
Old Sep 29, 2008 | 10:11 AM
internetautomar's Avatar
mod or sell?
1 nut, snap ring pliers and you are good to go
Old Sep 29, 2008 | 10:13 AM
enik23's Avatar
write up? my car had strange vibration when going 60+ took it to a mehanic he said change ur front right ball joint i have no experince doing that they said it would cost me 300 bucks so if i can do it myself save some money that'd be great.
Old Sep 29, 2008 | 10:39 AM
CRiME's Avatar
oem ftw!
Why do you always write "YES, I'VE SEARCHED", when you obviously never search?
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
and..
http://forums.maxima.org/4th-generat...ntrol-arm.html
http://forums.maxima.org/4th-generat...tions-pic.html
http://forums.maxima.org/4th-generat...t-out-hub.html
http://forums.maxima.org/4th-generat...r-tie-rod.html
Some people opt to replace the entire lower control arm instead. Obviously if you're trying to save money though and only have a bad ball joint, you can just replace the joint. maybe these pictures in the LCA writeup will help anyway though:
http://maxima.cardomain.com/ride/348507/15
To be honest, given the other questions that you've asked in the past, I think this is one that you should cough up the $$$ and have the mechanic do.
And, $300 is a rip off, so go somewhere else if you want to have it done... I had both LCA's done for $400, parts and labor. If i had a driveway and it wasn't 10 degrees outside at the time, I would have just done it on my own
Old Sep 29, 2008 | 02:20 PM
dgeesaman's Avatar
Maintenance Monster
Perhaps you've forgotten that the ball joint is press fit into the control arm.
Add a press or ball-joint C-clamp tool to the list. I was successful using a borrowed tool set from Autozone.
Old Sep 29, 2008 | 03:21 PM
mod or sell?
I thought it was held in by a snap ring, I know that is how the replacements come.
Old Sep 29, 2008 | 03:25 PM
dgeesaman's Avatar
Maintenance Monster
The snap ring is just a backup and I'm not sure what good it would do in that event.
It's a tight press fit between the arm and ball joint that transmits all the load.
Dave
Old Sep 29, 2008 | 03:42 PM
JtzMax's Avatar
Whatchyou say?
Dave is right ... it's pressed in and not that easy to take out. It can be done with said tools, but it is sometimes just as easy to replace the whole control arm.
Old Sep 29, 2008 | 06:00 PM
RA030726's Avatar
I'm nutty for Nissans
You dont need any special tools to press them out. A large pipe, large socket (ie axle nut), and a BFH work just fine.
Old Sep 29, 2008 | 06:01 PM
I co-sign these statements.
Old Sep 29, 2008 | 07:12 PM
JtzMax's Avatar
Whatchyou say?
Old Sep 29, 2008 | 07:15 PM
dgeesaman's Avatar
Maintenance Monster
It's a press fit, not a beat-with-a-hammer-fit. If you drive it out with a hammer I'm willing to bet you'll damage the bore of the control arm and compromise the fit.
Do it properly, get a press of some kind. Or carry the control arms to a shop and pay them $20 to do it on their press.
All that said, my recommendation is to buy a new control arm. The ball joint is of excellent quality (some ball joints you can buy are not worth the time to install them) and you get new bushings which most maximas would benefit from.
Dave
Old Sep 29, 2008 | 07:18 PM
MorpheusZero's Avatar
Yeah I was going to mention a BFH is the only press you need
Old Sep 29, 2008 | 07:32 PM
GStrength's Avatar
Where are you located? If you are new NJ I can change them for you at a price.
Old Sep 29, 2008 | 07:52 PM
maxima-junky's Avatar
Where do you people live that your paying 3 and $400.00 to get ball joints done. In NYC if I go to the Parts Authority and buy some ball joints, my fav driveway mechanic will do em for $30.00 a side. If I take em to a garage they'll do it for $80.00 all together. Mechanice where you guys live must make more money than Doctors.
Old Sep 29, 2008 | 08:05 PM
Love_00_Max's Avatar
I did my LBJs in my garage with tools rented from Autozone. The only thing that I forgot was a snap-ring plier to get the snap ring out. I don't believe the snap-rings are cosmetic, the damnnn this is made with space age high strength steel, though it is a few mm it is it very very strong and firmly fixes the joint to the arm. The entire suspension resting on the joint bolt is calling for serious trouble on the road, hook or crook the snap-ring needs to be put back into the groove to prevent the knuckle coming off the control arm.
BTW, without getting the snap-ring out, there is no way on earth you are going to get the LBJ off the arm. Period, ask me how I know.
Once the snap ring is out, just hammer the old one out. Putting the new one needs some effort. Put the new ball joints in the freezer all night to reduce the dimensions just enough to make it into the balllljoint hole. The Autozone balllljoint press did the job but then you will need some patience. The first one took me a long time but then with all the learning the second one was a breeze.
In all you will need close to 4-6 hrs to get the job done.
Old Sep 29, 2008 | 08:37 PM
GStrength's Avatar
Son that's mad cheap, being that the struts have to be removed, rotor removed, in order to use a press against the ball joint.
Old Sep 29, 2008 | 09:35 PM
rex3001's Avatar
hmmm FBH?
F***ing Big Hammer??
Old Sep 29, 2008 | 09:59 PM
enik23's Avatar
any one got a write up with PICKTURES how to change the damn thing?
Old Sep 29, 2008 | 10:02 PM
CRiME's Avatar
oem ftw!
PIicktures, no. But there are some pictures that might be helpful in the LCA writeup
No offense man, but if you had trouble installing the universal O2 sensors, and had no idea what to do with the wiring harness of your new HU, I really think you should let the mechanic tackle this. That job could get ugly if you're not 100% sure of what you're doing. If you are confident though, you can buy a Haynes manual. Should be a lot of pics & info in there. Again, don't mean to be an ***, but we don't really want your car to be down for weeks or otherwise unsafe if the job isn't done properly.But i'm not really sure how confident you are in your abilities when you make a post like:
okay im a total noooob when it comes to cars but.....
Just play it safe, shop around and get the best price on the work. You might want to consider buying the entire LCA and just having them install it. Ebay has them for $50, Autozone about $100. Some people don't trust ebay vendors, but I think nick got his suspension parts form ebay in that writeup and they've been holding up well.
Old Sep 29, 2008 | 10:25 PM
enik23's Avatar
hey you know what man i did get that damn radio to work and i did do alll the sensors along with knock sensor and whole buncha other shyet plus its a good learning experience. untill i saw max.org i never even opened the hood of my car
Old Sep 29, 2008 | 10:26 PM
enik23's Avatar
and another question the ball joint is located in the lower control arm right?
Old Sep 29, 2008 | 10:31 PM
It's great that you're learning but... you really need to invest the $10 in a Haynes (from Amazon.com) or the time and download the Factory Service Manual (FSM) for free.
Just trying to be helpful here.
Old Sep 29, 2008 | 10:32 PM
CRiME's Avatar
oem ftw!
How was I supposed to know you got it working, when you deleted the thread you made that had all the info I gave you in it?
But anyway, the links I gave you up top should be more than enough to get you started on this if you're serious about doing it yourself. If you ask me, this isn't really a job that you want to practice on. Knock sensor, O2's, HU, fine, but this is a pretty important part of your suspension. Your call man, the info is all over this site!!
Old Sep 29, 2008 | 10:34 PM
CRiME's Avatar
oem ftw!
Did you look at ANY of the links, at all? Yes, it is. Pic Taken right from the LCA writeup above:
Old Sep 29, 2008 | 10:54 PM
enik23's Avatar
ordered one 2 days ago lol 7 from ebay actually hope its as good as u ppl say it is.
Old Sep 30, 2008 | 07:27 AM
JtzMax's Avatar
Whatchyou say?
Haynes and Chiltons both are good for some stuff ... the FSM is more complete and free .... why not go that route? I have a Haynes and the FSM, all I need. Well ... and Maxima.Org!
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
ivorton23
Sep 26, 2015 09:47 AM
Noela
Sep 26, 2015 08:22 AM
