1st problem with the max
Old Sep 29, 2008 | 05:31 PM
Gtpowered4.6l's Avatar
I have an oil leak. I cant really tell from where but it is definitely my nice clean oil. It is coming from what would appear to be a rear main seal or it could even be an axle I guess. Right from that area on the drivers side
Old Sep 29, 2008 | 05:35 PM
HKIC's Avatar
could it be dripping down from the valve covers? thats what happened to me, now i have an oil pan leak supposedly. i cleaned the whole engine with degreaser and then after driving for a few miles checked where the oil was coming for... hopefully that helps
Old Sep 29, 2008 | 05:43 PM
nizzmo's Avatar
yeah i clean the eng off with brake clean and drive it and recheck or if u can get ur hands on some dye and check for leaks
Old Sep 29, 2008 | 08:25 PM
hot_wax_tree's Avatar
just clean her up and drive it a bit to figure out your leak
Old Sep 30, 2008 | 06:32 PM
I looked from the bottom up above the tranny and couldnt see much. I will do a more thorough clean and check this weekend. Thanks guys. I will keep the thread updated...
Old Sep 30, 2008 | 06:43 PM
CRiME's Avatar
oem ftw!
If you can get your hand back there, reach behind the upper intake manifold and feel the back of the rear valve cover. I did this to confirm that's where my oil leak was coming from. When I tried it my hand came out covered in oil. The job is not really a difficult one to do on your own, it should take you half of a day at most even if you have little experience. Be sure to change the spark plug tube seals too while you're back there, if the rear VC gasket does end up being the problem.
Edit: if the leak is coming from your driver's side, then I'm not sure if it's so likely to be the rear VC... I think typically the rear VC leaks down the pass. side area. At least, that's where mine leaked to . It wouldn't hurt to check it out anyway, I guess?
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
boomerbrian
Oct 31, 2018 10:25 AM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
